Old 04-24-2015, 08:52 PM   #1
No heat, fan is running??
08 37x16 Just brought the trailer home from winter storage, everything seems to be working except the heater the fan is turning on and cycling for 20-30 seconds but there is no ignition of the LP. I am a new owner of it just buying it last summer used it a couple times so I'm not sure if I'm just doing something wrong? The stove is working and the fridge is working on propane. I do recall this doing the same thing last year and I can't remember what I did to fix it or if it just started working but I know I did have heat last summer.
burnt toast is offline   Reply With Quote
Old 04-24-2015, 09:01 PM   #2
B and B's Avatar
Hello,
Certainly sounds like air in the lines. It might take a few tries to get it to light.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-24-2015, 09:17 PM   #3
U think I have tried it like 10 times? And no igniter or solenoid clicking.
Old 04-24-2015, 09:33 PM   #4
Flybob's Avatar
Some units will go into fail safe mode after a few failed attempts. Turn it off ( not just down) and it may reset the fail safe.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-24-2015, 09:45 PM   #5
caper's Avatar
Are you on house power or running off battery? If you are on 12volt voltage might be to low to allow furnace fan motor to come up to speed.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-24-2015, 09:58 PM   #6
I'm plugged into the house, batteries were pulled over the winter and are fully charged
Old 04-24-2015, 10:01 PM   #7
B and B's Avatar
Possible air intake restriction? Mouse or something like a wasp nest? Air restriction would cause issues with airflow switches/
Old 04-24-2015, 10:22 PM   #8
Air flows good through the vents when the fan is running not a blocked intake
Old 04-25-2015, 10:18 AM   #9
northstar1960's Avatar
if the exhaust for the burnt gas is clogged the sail switch will not make contact and prevent ignition check your outside vents both combustion air in and exhaust out . also you could have a bad pc board , this can still allow the fan to run but not ignite the furnace . I don't know if this furnace has a lock out after so many failed attempts but like mentioned above shut the power to the unit down for a minute and then try again . if still no ignition then look into thew sail switch or pc board . you;ll have to pull the unit out
northstar1960 is offline   Reply With Quote
Old 04-25-2015, 11:40 AM   #10
I had the same problem with mine. It turned out to be the control board. Was still under warranty so they replaced it for free for me.
Sac3100 is offline   Reply With Quote
fan
