Old 04-02-2016, 11:38 AM   #11
WolfWhistle's Avatar
Chrism, this is pretty simple to explain, but I sort of want to attach a photo... but... what I did was run a #4 awg and a #10 awg from the distribution block (now relocated) at the front of the unit B+ to the utilities access compartment (I jokingly call it REAM) where I fused the #10 to run both the cigarette lighter ports (dual) in the pantry (lower doors) and to a WP plug on the outside (by the other plugs) to power my Winegard CarryOut.
By running to +B I don't need 120vac. I typically use those ports for USB charger adapters at this time.
I also ran #10 and #4 ground to the frame directly below.
The #4 awg is for audio power (head unit, two amps and capacitor) located in the pantry cabinet. Where I distribute through breakers.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-06-2016, 04:50 PM   #12
Chrism28's Avatar
I really just want one by the tv so I can run a inverter to watch so I don't have to run the gen I have a 12volt tv for the garage
Chrism28 is offline   Reply With Quote
Old 04-06-2016, 07:19 PM   #13
I'm not sure how well a small inverter with a cigarette lighter plug would work, you still have to have very little voltage drop from battery to inverter I would get it as close to the battery as possible and maybe run an extension cord from inverter to TV. Voltage drop on the 120 vac side isn't an issue.
WW
