Old 08-19-2015, 02:11 PM   #1
Outside shower trouble
I have a 15 nitro xlr and I have used the outside faucet b4 but now I am having trouble getting the quick connect blue coul hose on. Any suggestions?
Arkguy29 is offline   Reply With Quote
Old 08-19-2015, 02:18 PM   #2
KenHwy61's Avatar
Mine was difficult to use and even more so if there is pressure on the line. I took off the original quick connect and replaced it with a standard male hose fitting. Works so much better and allows the use of any hose with a standard hose end.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is online now   Reply With Quote
Old 08-19-2015, 06:59 PM   #3
I had the same problem. We unhooked the city water and turned an inside faucet on without turning on the pump. Once the pressure was out of the lines, the hose hooked up.
2014 XLR27HFS
2006 Ford F450 Dually Diesel
breezyhillfarm is offline   Reply With Quote
Old 08-19-2015, 07:37 PM   #4
Like the other poster suggested, you are expierencing back pressure in the quick connect fitting. You need to dump pressure then connect. What I was able to do was flip the housing 180 degrees so the hose storage door can remain open ,while closing the compartment door. That way I leave the hose connected with the nozzle in the shut off position, and don't run into that issue.
I do not know your actual set up, but that might work in your application as well.
Old 08-19-2015, 11:32 PM   #5
Old 08-19-2015, 11:34 PM   #6
Sometimes I take a small screwdriver and poke it where you plug the hose in on the quick connector. This relieves the pressure then hose plugs in with no problem. Just remember water will squirter at you!
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
dennismo is offline   Reply With Quote
Old 08-20-2015, 10:37 AM   #7
I had the same issue, the spring loaded seal is just stuck. I tried poking it at first but found it was easier to take it apart and reassemble had mine fixed in less than 2 mins
Berjr1 is offline   Reply With Quote
show, shower
