06-05-2015, 09:39 PM
CUZISA2
Overpasses
Our XLR 340x12 measures 13'2" at the highest point. Since we are new to a 5th wheel height, do any of you have suggestions on traveling? The interstates are all acceptable heights but how can you find out if a secondary roads overpass is high enough going to a campground. I'm suspecting that I just need to ask when I make a reservation but was curious about what others do.
06-05-2015, 09:44 PM
We are investing in a GPS system (not sure name of it because DH is handling that issue) that tells you the height of any overpasses on your projected trip path. We took our 5er on an initial shake down cruise last week and as we drove down the road we were talking about some things and all of a sudden DH said "OH ****!" Scared me to death...then he explained that as we approached an overpass he realized we had only like 6" clearance (and sometimes these overpasses do sink a bit). We made it fine but it reinforced to us that we need to get this system before our next trip.
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
06-06-2015, 05:08 AM
I use the all stays camping and RV app.
I check my route with the app before we leave on any trip.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
06-06-2015, 05:15 AM
I would just call the camp ground, tell them the direction of travel odds are they will know of any problems leading to their location.
06-06-2015, 06:27 AM
The overpass don't sink. But they do pave under them. Adding an inch or two of blacktop every time raises road
2015 29 hfs / 06 gmc 2500hd
06-06-2015, 06:58 AM
Don't they typically grind the old asphalt up before repaving? That is what I see done around my area.
2016 Flagstaff 23LB
06-06-2015, 07:05 AM
The is an Android App called Low Clearance Locater. I wouldn't be without it.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
06-06-2015, 08:05 AM
I use a Rand McNally GPS unit for RV's. In the RV set-up section the user states the parameters for the camper such as height, length, width and so forth. The route for towing is than computed by the GPS using these parameters. So far it has been accurate, but I still use paper maps and common sense.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
06-06-2015, 08:21 AM
Use a garmin 760
Same as the post above just gar mins version. There are some areas it does not know in Canada though, warns you it is not sure on your access. Used on a trip to the U.S. it work well, does more then just height, propane and tunnels as well,
2015 Sandpiper 30IOK
2019 GMC 2500HD 6.6 Duramax
06-06-2015, 08:22 AM
our camper hooked up is 13'5" so we are also worried about this. Legal height is 13'6" most overpasses will be ok. I believe semi van type trailers are 13'6' we ordered a truckers atlas which has bridge height in it, still thinking about moving hitch up on camper it will lower camper about 1" we'll be watching close all overpasses.
Matt & Sondra
2016 Sierra 377flik
2003 F350 6.0 Powerstroke
Curt Q20 hitch
06-06-2015, 08:29 AM
Having worked in the trucking industry for 33 years, I can tell you not to believe the posted height on an overpass. Many different circumstances conspire to change the height by one or two inches, lower or higher. The best thing to have is a truck or RV specific GPS which routes with clearances in mind.
Rick
2015 Work and Play 30WRS
2011 Ram 2500 I-6
06-06-2015, 08:46 AM
Saw this video when researching the subject myself. Painful to watch a couple a/c's be squeegeed from their roof.
-R.Jones
Ordered Nitro 31fqsl
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
06-06-2015, 09:05 AM
Garmin 760RV, saved my bacon in Spokane...it was $399, but worth the price when considering the cost of one repair bill from hitting an overpass! That model also will route you around weight/length/width restricted areas once you input your own rigs numbers. I recommend it!
2015 36DBK5
2015 Chevy 3500 dually
06-06-2015, 09:07 AM
Painfull was my stomach hurting from laughing so hard!
Most campsites even tell you on there web site routes not to take.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
06-06-2015, 10:22 AM
I also use the Rand McNally GPS (7720 I think). One caution - it will only route you around low clearances IF you are following route to a specific destination (e.g. the campground). If you are just using the map feature and driving around, it will not warn you of low clearance.
Another good resource is a Truckers Road Atlas. Has low clearances listed in a table by state, then by highway and location.
Jim - I'm from Oswego, NY.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
06-06-2015, 12:43 PM
I had the Good Sam site route us and I went under a underpass that was way too close. I called them and they said even what is listed on signs at the overpass maybe incorrect. We got lucky by a few inches. Scared us badly. I like the GPS idea but I'm not sure if I trust that either. Calling camp ground maybe best.
2014 Sabre 33CKTS
2012 F250
06-08-2015, 01:00 PM
CUZISA2
Thanks everyone. We'll look into updating our Garmin. We haven't used it since the phones do so well with directions.
