Old 04-25-2016, 06:37 PM   #1
Permanent Ladder
Anyone installed a permanent universal ladder on a 29HFS? I've been hauling a 6' ladder to be able to sweep leaves and such off the top of the slide before closing. I'd like to install a permanent ladder.
2015 XLR Hyper Lite 29HFS
2013 Silverado LTZ 2500 Duramax
2016 Jeep Wrangler
2005 Corvette Coupe
lkj831 is offline   Reply With Quote
Old 06-13-2016, 06:29 AM   #2
Where do you stow the ladder? I store ours in the rack that is aft of the wheels and was the area for the fuel tank. I simply took a 2x2, separated the frame used it as a spacer and added longer bolts. Easily out of the way.
laurajean is offline   Reply With Quote
Old 06-13-2016, 06:40 AM   #3
jeff64's Avatar
When I had the previous Jay Flight that didn't come with a ladder, the dealer said that it needed to have some type of backing structure built into the wall from the git go and it couldn't be done after the fact. I carried a 6' ladder in the front pass through for just what you are speaking of. I did have to pay attention that the ladder would be narrow enough at the base to fit. Lesson learned! This TT was ordered with the ladder and slide toppers from FR
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
