Originally Posted by rebel29144
Are you getting newer axles, or just heavier suspension,
will it be much taller off the wheels, how much do they quote you for this?
Trying to see if I should do this, mine drags at rear in spots.
thanks for any info
Another quote: Wolfwhistle, did they tell you how much higher it would ride with the heavier suspension? The height is already 11' 6", will it push us into the 12' range? Of course loaded it will be back down.
Hey guys... FR sent the dealer, 5200# axles, springs and equalizers. All other components will move over; such as wheels and tires, brakes and hardware. I was told it would be taller, but how much exactly, I don't know.
I hoping the change will not raise it more than 2 inches. The brochures I've read says a 29HFS should be 11' 2" tall.
It is a factory safety recall, so no charge.
Do you mean (rebel) it drags on steep drives or entrances? I haven't had mine drag in the short time I've owned it... pulled it about 4K miles... into Canada, Up state NY, PA, MD, Va, etc. Raising it up on the springs, certainly will help but not eliminate this issue.
You could drop the front down a bit, giving it a more front end lower attitude... which you would want it to be mildly front end low normally; and / or get some rollers for the rear... to prevent damage to the unit. Can you tell if your axles hit the frame?
Drag Rollers on etrailer.com Search
