Old 05-04-2013, 03:31 PM   #1
leadhead358's Avatar
Pictures of RZR 800 in hfs27
I looked all over this forum, but I could not find any pictures of a RZR in a toyhauler. So here you go. I hope it helps someone on making a choice. I can tell you it will fit with brushguards on, BUT it will rub the ramp and bath doorway. It is very tight. I took the front brushguard off (only 4 bolts) and that gives you about an inch in the back and 1/2 inch in the front. I will put blankets at front and back so it doesn't rub. The RZR is backed in.
A RZR 900 may not fit in length. I know they are wider then the 800, but I am not sure of the wheelbase.
Height is not a problem or width. I think it would fit under the rear bed when raised. I took mine out.
ID:	29580   Click image for larger version
ID:	29581   Click image for larger version
ID:	29582   Click image for larger version
ID:	29583   Click image for larger version
leadhead358 is offline   Reply With Quote
Old 05-04-2013, 07:39 PM   #2
It does fit, with room on the sides for some little things.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
