Old 07-19-2016, 09:25 PM   #11
northstar1960's Avatar
the motors stop when the amp draw increases . you can try to sync the motors back up . unit needs slide either all the way in or all the way out. then run it about 8 inches then run it back in or out and hold the switch till it stops on it's own . do this a few times and it should sync the motors .
there is a over ride on the controller . make sure all the connections are good . there is a button in the middle of the controller push it 6 times and on the 7th hold it in the contoller should start to flash and then you have about 60 seconds to run in and operate the slide . this mode overrides faults . to get your slide in . if all else fails unplug the motors this will allow you to push it in manually . then be sure to plug the motors back in as this is what keeps the unit from moving
northstar1960 is offline   Reply With Quote
slide, slide out
