Old 06-29-2011, 07:36 AM   #11
Herk7769's Avatar
You should always carry a cheap voltmeter (10 bucks anywhere) and a test light with you at all times. An outlet tester works wonders to make sure your campground is supplying correctly wired power.
How did you "check your fuses" without a ohm meter?
Did you just look at them? Not always reliable.
We may need to go inside the converter to troubleshoot next so if you are not at all handy with electrical items (and your lack of a voltmeter is a red flag) you will NEED to go to the dealer.
HAM CALLSIGN - KC3FFW
Old 06-29-2011, 07:39 AM   #12
i might be able to get my hands on one.
summersoff is offline   Reply With Quote
Old 06-29-2011, 08:25 AM   #13
Inveterate Tinkerer
Iluv2fish's Avatar
Try a different battery first...might have just given its last gasp, and it is the simplest thing to try. Modern batteries now fail suddenly and completely in some instances.
Randy
Randy and Cheryl
Sir Guinness-(Manchester Terrier)
2012 Windjammer 3065W
Chevy 2500HD Duramax/Allison
ProPride 3P
Iluv2fish is offline   Reply With Quote
Old 06-29-2011, 09:55 AM   #14
jimh's Avatar
I have inadvertnally unplugged my converter moving thing around. Check that. Batery as suggested above do interesting things.
jimh is offline   Reply With Quote
