Old 05-17-2012, 11:11 AM   #1
Putting sheets on the bed?
We love our 2012 XLR 27hfs but putting sheets on the bed is definitely a challenge. I just came in from changing the sheets and have worked up a sweat. I would have given up a couple of inches at the table area just to gain enough room to tuck the sheets in around the bed!! Any tips or tricks?
kathy
2012 XLR Hyperlite 27HFS
2010 Ford F250
2010 Harley-Davidson Softail Custom
kathys85 is offline   Reply With Quote
Old 05-17-2012, 12:12 PM   #2
trudinator's Avatar
There really are no tricks to it. I do a lot of rolling side to side when I'm putting them on by myself. And like you, I work up a sweat doing it! We also use the elastic sheet "suspenders" (Wal Mart, $5 a set) to keep the bottom sheet nice and tight, since we have a short queen and are using regular size sheets. The only tip I can give you is to enlist your DH to help you. It works much better with 2 people!!
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 05-17-2012, 12:41 PM   #3
Rugged Brown's Avatar
I've been enlisted and it works better with two.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 05-17-2012, 02:07 PM   #4
Sounds good. I will give it a try with 2 of us.
kathy s
2010 Ford F250
Old 05-17-2012, 02:31 PM   #5
Our bed is in the center line. we stand on each side of the bed to make it.
We use fitted sheets, so we pull the mattress down so we can reach the upper end easily. After fitting the top, we push the mattress back in and continue to make the bed.
Easy and fast.
hankpac is offline   Reply With Quote
Old 05-17-2012, 07:04 PM   #6
Earth Station's Avatar
We had little room in our TV and was told to put peel and stick tiles under the bed. I did the same in out new FW and it works like a charm. I appreciate the help from DH but I can do it alone now also. And -- I don't have to roll around on the bed or be a contortionist!!! Hope this helps!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 05-18-2012, 09:18 AM   #7
Wait, I don't understand the peel and stick tile under the bed? You mean so the mattress will slide around easier?
kathy
2010 Ford F250
Old 05-18-2012, 05:14 PM   #8
yes Kathy -- exactly.......... the sticky side down....... the mattress won't move when traveling but will slide easy to make!!! One of the first mods I did to our new fw!!! and I have much more room now then I did in the tt
Old 05-18-2012, 08:37 PM   #9
OK Great. Thanks for the tip. I will try it.
Kathy S
2010 Ford F250
bed
