Old 05-14-2012, 02:29 PM   #1
Question about load - boy this is confusing.
I may have the opportunity to swap our trailer for a 19hfs XLR and I have been trying to learn as much as possible about towing capacities.
Maybe someone can help me a bit. Here goes.
XLR 19hfs
Trailer Weight: 4,372 +
Bike: 815 (wet) +
Gear for two: 500 +
Gas, misc etc: 500
Total: 6,187
Tongue Weight: 618 (assuming 10% - most of bike is over axels and behind)
2011 Ford F-150 XLT 4x2 - Ecoboost
Trailer towing package but not max tow.
3.15 gearing
GCWR: 14,000
Max loaded Trailer weight: 8,500
Max tongue without WD: 500
Max tongue with WD: 1,130
Base Curb Weight: 5,287
Gear / People in truck / full tank: 544
Can someone take a quick look and see if this is going to be an issue? I have tried to plug in the numbers but I am not exactly sure if I have everything.
Lpboy is offline   Reply With Quote
Old 05-14-2012, 02:50 PM   #2
What is the trailers GVWR? What is the trucks ready to travel weight? That means full of gas, people gear etc etc etc.
Old 05-14-2012, 03:55 PM   #3
Herk7769's Avatar
Stuart,
There really is not enough to go on here.
I would need the cab type and bed length for starters.
http://www.rvwholesalers.com/resourc..._Lite_2012.pdf
HAM CALLSIGN - KC3FFW
Old 05-14-2012, 05:37 PM   #4
Hi Herk,
Sorry about that. Trying to learn. It's a super crew with a 5.5 ft bed.
Stuart
Old 05-14-2012, 05:59 PM   #5
Herk7769's Avatar
Originally Posted by Lpboy View Post
Hi Herk,
Stuart
Stuart,
I hate to tell you this but I am going to work up your numbers. That 3.15 rear is going to just kill you.
Old 05-14-2012, 06:35 PM   #6
Yeah. I expect that. The surveyor 189 pulls fine mostly in 6th but this is a couple thousand more. Luckily we live in south Georgia and spend most of our time in Florida. Flat as a pancake.
Thanks again for the help.
Old 05-14-2012, 06:45 PM   #7
Herk7769's Avatar
2011 Ford F-150 | View Full Specification Library | Ford.com
http://assets.forddirect.fordvehicle...1E31E15E1E.pdf
For the Truck:
2011 F-150 Super Crew XLT 4x2 w/ Ecoboost 3.5L and 3.15 rear
154 inch WB No Max Tow Package
GCWR - 14,000 pounds
GVWR - 7100 pounds
Max Payload - 1760 pounds
Curb Weight - 5340 pounds (as equipped)
Max Trailer weight (Travel Trailer) - 8800 pounds
The Trailer:
UVW - 4372 with a hitch of 532 = % Tongue = 12.2%
GVWR - 7532 with a 12.2% tongue = 919 pounds
Using your numbers for your camper of 6187 pounds loaded
and 544 pounds of gear in the truck (including hitch weight):
The truck will weigh hitched 5340 + 544 + 755 tongue = 6639 pounds
Good To Go!
Camper will weigh 6187 (less than 7532) - Good To Go!
Your Combined weight of 12,826 pounds (less than 14,000) - Good To Go!
So, the good news is you will be "legal" and the bad news is your rear end will make your gas bill high.
Old 05-14-2012, 07:13 PM   #8
Man thanks Herk! You are truly an asset to everyone! I hate that the rear gearing is so high but at the time, pulling an rv was norton the immediate horizon.
Thanks again!
led pad
