Old 06-09-2015, 01:05 PM   #11
darvinstone's Avatar
You should have two batteries, one on each side. Inverter is wired to one battery and they may not be connected together. You will need to run a positive from main battery to second battery so the inverter will stay charged during towing and shore power.
Stan Stone
Lexington, NC
2016 XLR 375 AMP Thunderbolt
2014 F350 Lariat FX4 DRW (Fully Deleted)
darvinstone is offline   Reply With Quote
Old 06-09-2015, 01:17 PM   #12
There are 2 batteries and 2 inverters, the main inverter and battery and the refrigerator inverter and battery. What I'm not sure of is if from the factory they set it up so that the refrigerator battery will charge from the main inverter while plugged into power or while running, or if the refrigerator inverter needs to be on for the battery to charge.
wrsmsgt
2012 HD 2500 DuraMax
2015 XLR ThunderBolt 340x12hp
wrsmsgt is offline   Reply With Quote
Old 06-09-2015, 01:58 PM   #13
You need to verify both batteries are tied together since the main battery is the only one wired to charge during tow and shore power. I know this because mine was not tied together from the factory.
Stan Stone
Lexington, NC
Old 06-09-2015, 02:43 PM   #14
Very good I'll do that and run a wire between the batteries. Thank you
wrsmsgt
Old 06-09-2015, 04:41 PM   #15
I believe I'll wire the batteries together though an isolator
wrsmsgt
Old 06-09-2015, 07:24 PM   #16
Make sure you use heavy duty battery cable....
Stan Stone
Lexington, NC
battery
