Old 01-07-2016, 10:31 AM   #11
John513
JohnRiordan's Avatar
Yes on the 15K
JohnRiordan is offline   Reply With Quote
Old 01-07-2016, 01:22 PM   #12
WolfWhistle's Avatar
Excellent report Dave!
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-07-2016, 07:37 PM   #13
2014 XLR 27HFS
Thanks Wolfie...
BTW Crop Duster, you will love the XLR - great camper. WW and I can give you all sorts of modification ideas to make it even better.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 01-27-2016, 11:29 AM   #14
Hedrock's Avatar
Question Regarding Installing Generator in XLR 27HFS w/ Prep Pckg
Closely related I think... I want to add a genny to my 30 HDS. It is prepped for one now just not sure I want to lose the space. If I choose to not use an onboard genny will my fuel station still work? If I go with an onboard what size do I need with a 15k a/c?
Thank you for any suggestions.
2016 Hyper Lite XLR 30HDS
Hedrock is offline   Reply With Quote
Old 01-27-2016, 01:24 PM   #15
chpence1's Avatar
I wish I had a diesel Onan instead of gas.... I believe they are quieter.
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 01-27-2016, 01:31 PM   #16
They are a touch quieter. The 6k diesel is 66db and the 5500EVAP I have is 69db. If I was going to upgrade mine though, I'd stay gas and go to a 7k EFI. It's a plug and play swap other than swapping the pump and adding a return line. Both are very easy... Talking the wife into the cost of the upgrade is a hair more difficult....
Karl4Cat is offline   Reply With Quote
Old 01-27-2016, 11:26 PM   #17
Play Harder's Avatar
I have the 4k onen and 2000 Honda the Honda is by far quieter barely know it's on when running a few feet from toyhauler and never have had a camper near by complain about the Honda - but the onen you 100% know when it's on it's loud and yes I have the supposedly silencer extension exhaust kit
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 01-28-2016, 12:16 AM   #18
Crop Duster's Avatar
dave961, I may take you up on the idea for making it better. The first modification for me will be a wood stove. And then I should have some time this summer to add a few more things. Off hand, have you added a flip down counter at the edge of the sink in front of the door? I'd like more counter space and have thought about doing this....
PH, maybe a Honda is the way to go.
Crop Duster is offline   Reply With Quote
Old 01-28-2016, 07:26 AM   #19
chpence1's Avatar
If I remember correctly db is not linear, it is exponential.
3db is noticible difference.
We previously used two Honda 2000, singularly for satellite TV and others and as a pair when when running AC and microwave. We had an external fuel tank that would feed both. The fuel usage was awesome. The noise with one wasn't so bad but two wasn't exactly that great. Carbs weren't cheap.....
Cow Bell
Old 01-28-2016, 07:40 AM   #20
Will one EU2000i Honda run the microwave or do you need two for that?
generator, xlr
