Old 01-28-2016, 08:05 AM   #21
chpence1's Avatar
One 2000 Gen
Depending on onboard wattage that running a 2000 watt Honda will run a small RV microwave (1000 to 1200)
Remember all wattage adds up (load1 + load2 + load3) to total load on generator.
When under a large load Honda generator will scream when running.... very loudly, until microwave finishes. The PR folks don't mention this they only talk about idle noise or exceptionally no load.....
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 01-28-2016, 08:23 AM   #22
We have two Honda 2000s for our Work & Play set-up. One 2000 is good enough that I rarely hook both up in parallel unless I know I'll be running the AC. We can be watching TV with the fridge on and maybe a light or two and although it does start running hard, the wife can turn on the convection microwave and it won't miss a beat.
2017 Ford F450 Lariat 6.7L
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 01-28-2016, 08:51 AM   #23
That's the setup we had before getting our first toyhauler. We were very pleased with it. That said, I could never go back after having a built in. So much more convenient.
Karl4Cat is offline   Reply With Quote
Old 01-28-2016, 09:28 AM   #24
Play Harder's Avatar
I only run one 2K Honda it powers everything except the AC
AC I use the onen 4K
With onen mounted right under your bed and to the frame - you definitely know when it's on - I even put sound Db blocking insulation around it - which helps
Play Harder is offline   Reply With Quote
Old 01-28-2016, 11:02 AM   #25
WolfWhistle's Avatar
Originally Posted by chpence1 View Post
If I remember correctly db is not linear, it is exponential.
3db is noticible difference.....
You are right it isn't linear, dB is a ratio of power in to power out. Each 3 dB increase doubles the power; amplitude (voltage) is doubled every 6dB, however to the ear, perceived volume doubles at about every 10 dB increase.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-29-2016, 08:08 PM   #26
2014 XLR 27HFS
Originally Posted by Crop Duster View Post
...Off hand, have you added a flip down counter at the edge of the sink in front of the door? I'd like more counter space and have thought about doing this.....
I have not, but others on this site have. I've seen other posts about rolling carts. I think if the cart was the same height as the table, you could set it up next to the table and gain a lot more 'counter' space that way. When not in use, you could wheel it into the garage.
Dave & Audrey
dave961 is offline   Reply With Quote
generator, xlr
