Old 04-16-2012, 11:10 PM   #11
The white valve he installed replaced this hose/cap where you can drain it. But, I'm wondering what he did to the front. All are pretty fragile and low (albeit the fresh water is more fragile as it's more fixed)
GaryRudolph is offline   Reply With Quote
Old 04-16-2012, 11:12 PM   #12
I had the same thing on my last trailer. I cut them off as short as I could and re-installed the fittings/valves. I bought a special crimper and rings from Home Depot.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-16-2012, 11:14 PM   #13
If it were me I would get rid of that blue extension and replace it with a threaded ball valve.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 04-17-2012, 01:50 PM   #14
jonnys_walkers's Avatar
I would take all the hose off and put a street elbow in with the a valve on it.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-18-2012, 09:06 PM   #15
Steve38's Avatar
If you don't mind, what did you do to the red/blue lines closer to the front where they come from a T?
It's on my list to address when I get a chance (Trying before this weekend before the next trip).
I will add 90degree elbows to them when I can get to them. They were not as low as the fresh water drain. They are on the mod list. Too many projects in front of them.
Steve38 is offline   Reply With Quote
Old 04-20-2012, 12:36 AM   #16
Ended up buying the crimper for the drains in the front, cut shorter and added a valve to make it easier. Now it doesn't hang down.
On the fresh water tank just found a small valve I could screw in with a coupler. Now, it's a little above the sewer lines.
But, still debating about flipping the axles.
Old 04-23-2012, 07:23 PM   #17
abanks's Avatar
Bought (2) pex pipe turn outs at Lowes for $2.00, 1/2" adapters and 1/2" PVC ball valves and pipe.
abanks is offline   Reply With Quote
Old 04-23-2012, 07:24 PM   #18
abanks's Avatar
Total bill including threaded elbow for fresh water tank was under $20
Old 04-23-2012, 07:25 PM   #19
TURBS's Avatar
stellar job !
Old 04-23-2012, 07:27 PM   #20
Drinkin beer on the beach
Rod Johnson's Avatar
Thats looks great....
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
