Old 06-03-2013, 09:00 PM   #1
Ramp door
Anyone had a problem with their ramp door? This is what I discovered today. Never overloaded and am very careful with supporting ramp if not hitting level. I load my Brute Force 650, about 600 lbs and my scooter, under 200 lbs. I have used it as a deck but never more than 2 people.
meandmylabs is offline   Reply With Quote
Old 06-03-2013, 09:28 PM   #2
Linnemj's Avatar
When viewing the picture, it is hard to determine what is wrong. Please provide more information.
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
Linnemj is offline   Reply With Quote
Old 06-03-2013, 10:21 PM   #3
10x
I see that crease line protruding outward. You need to take it to the dealer and see what they say. That does not look right.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 06-04-2013, 05:55 AM   #4
Yes, as 10X noticed, there is a crease line that has appeared. To me, this would imply that the door has been overloaded or sprung by not being level where it touches the ground. Neither of the conditions have taken place. I will contact my seller today and keep you informed. Just wondering if other XLR owners have had similar problems. I seem to remember another similar post but it might have been on a different forum.
Old 06-04-2013, 07:03 AM   #5
I load a 3-wheeler and a full dresser on mine and the weight is around 1,100 lbs and 1,200 lbs with me on them. You should be under weight on yours. Definately call the dealer about it.
Top B is offline   Reply With Quote
Old 06-04-2013, 07:06 AM   #6
Mark S's Avatar
My Work and Play ramp developed a crack in fiberglass and felt soft just above hinge where motorcycle wheels passed over. Door was replaced under warranty.
Although I was well within the weight limit, all the weight of the motorcycle was concentrated in a very small area over the hinge. I had a 2 ft by 2 ft, 1/4 inch diamond plate with a small lip made to spread the weight as I drive in. I don't know what the ramp cost but I can't imagine it was too cheap.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 06-04-2013, 12:52 PM   #7
10x
I remember the same post, it was on this forum. Someone also posted a source that makes a diamond plate cover over the hinged part of the ramp. Does anyone remember who sells it? I might have to do this from what I have heard. I have yet to load my Harley on it yet.
2014 XLR 27 HFS
Old 06-09-2013, 04:48 PM   #8
Any sheet metal shop should be able to shear a piece of heavy gauge aluminum diamond plate and using a break bend it to the angle needed. The only thing is how wide does it need to be and how much angle in the bend since the ramp door may not always be at the same angle. Maybe two pieces of plate with a heavy duty piano hinge in the center would work better because the plates could change angles. Just a thought.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 06-09-2013, 05:36 PM   #9
10x
There is a company with what you described that makes a hinged version that connects to the door. Link was posted on this forum but I can't find it.
2014 XLR 27 HFS
Old 06-09-2013, 05:46 PM   #10
10x
I found it
Toy Hauler Cabinets and Storage Accessories|Pit Products
2014 XLR 27 HFS
