Old 04-06-2016, 05:06 PM   #31
Here are some pics of the pieces I made and how they fit on the door. So far, I haven't drilled any new holes through the door. I have drilled some holes on the side pieces of aluminum trim, but they do not go through to the outside. I am undecided about drilling a holes through the door, and the 4 pieces of aluminum I added to the outside, to anchor those pieces at the top.
andy29847 is offline   Reply With Quote
Old 04-06-2016, 09:13 PM   #32
2007 WildCat 32QBBS
05CrewDually's Avatar
Does anyone remember how much weight they rated the ramp to hold when loading?
05CrewDually is offline   Reply With Quote
Old 04-06-2016, 09:43 PM   #33
wyo700's Avatar
If I remember right my ramp is rated for 3000 pounds. I load a 1500 pound sidexside on mine and haven't seen any issue yet.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-06-2016, 10:31 PM   #34
I carry 3 motorcycles - none heavier than 500 pounds. Weight was not a factor regarding the door failures I had. If you look close at the pictures above, you can see that the door is bending in the opposite direction than what you would expect if there was a load on the door.
Old 04-06-2016, 10:55 PM   #35
2007 WildCat 32QBBS
Don't take my question the wrong way. I am asking for my own knowledge for the future hauling my own "toys".
Old 04-11-2016, 07:19 PM   #36
FWIW, I removed one of the 6 springs on the ramp door. There is no appreciable difference in the effort to raise and lower the door with one less spring.
Old 04-11-2016, 07:42 PM   #37
If your door is rated like mine, the total weight is 3000 pounds and the max weight on any one wheel is 1000 pound. I think the "patio" limit is 1500 pounds.
Old 04-11-2016, 10:04 PM   #38
2007 WildCat 32QBBS
I don't even have a door yet! I'm asking for the future when I buy one eventually.
Old 04-12-2016, 04:32 PM   #39
Homebrew's Avatar
Nice job ! I don't have a patio ramp but starting to see the twisting at the corner starting. Your corner plates look like they could solve the issue, but bolts may need to go all the way through.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 04-12-2016, 06:45 PM   #40
The 5 number 14 x 3/4 self drilling screws I used on the corner plates are STRONG. I like them because I avoided drilling holes through the door.
I wish it was easier to remove springs. I'd remove the one in the center (giving me 4). If I can get the end of the door on the ground, without too much pressure on the hinges from the springs, and still be able to raise and lower the door by myself, I would be very happy.
A current unknown is how much the springs will "give up" with use. Here's how my door hangs with 5 new springs...
door
