07-23-2015, 03:33 PM
Ramp too steep for my new trike
I hope to get some wisdom from the gurus on the site. I have a 2014 XLR27HFS. I just purchased a Harley freewheeler trike and found that I can get it up the ramp but cannot get it down the ramp. The pipes will bury themselves in the dirt backing down the ramp. How can I get less of an angle on the ramp so that my pipes will clear the ground as I go up and down? It's the ground to ramp angle and not the hinge angle that's the problem. Thank for any wisdom.
07-23-2015, 03:35 PM
Can you back in? If not may have to come up with something where you can have the ramp off the ground a little.
2012 Sandstorm 203SLC
2013 Toyota Tundra Crewmax 5.7
2014 Honda Pioneer 700-4
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2004 Yamaha Grizzly 660
07-23-2015, 03:36 PM
It has a "starter motor" reverse, which is designed for getting out of a parking space and that's about it.
07-23-2015, 03:38 PM
Add a speed bump on the ramp. Look up quote #77 on the thread "what did you do to your Hyperlite XLR today" under the XLR category. WolfWhistle has a great explanation.
You could take what he posted and maybe apply to the bottom of the ramp.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
07-23-2015, 03:42 PM
Thanks oldgold. That post seemed to be about the hinge angle unless I read it wrong. My problem is the ramp is too steep at the ground.
07-23-2015, 03:44 PM
Raise the front of the trailer?
07-23-2015, 03:46 PM
Always Learning
Can you get make a triangular wedge to raise/extend the end of the ramp? That seems like it should lessen the angle from ground to ramp. Not sure how long it would have to be, though.
07-23-2015, 03:47 PM
just throwing it out there but what about getting some aluminum ramps like those used to put bikes in the back of trucks and then placing those behind the rear wheels on the ramp before it comes to the end. could probably even find a way to quick release them on the ramp.
I don't have an XLR but wife says her heart skips a beat every time I load my Road Glide into the back of my 351-THSS because she has measured that my rear fender comes within 2 inches off the ground.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
07-23-2015, 03:48 PM
Put the speed bump on the bottom of the ramp so your back end raises while the front end comes down the ramp some. It should prob be enough for the pipes to clear.
It may only take a 2x8 laid across at the bottom.
07-23-2015, 04:40 PM
Also just thought that I only need two ramps for the rears as the front coming down in the middle would raise the back end, right?
07-23-2015, 04:49 PM
This probably would work really well as high as my front jack will go. But we have a 30fqsl TT.
It definitely helped while changing a flat tire. I only needed an inch more to get the rear wheel off the ground while the front tire was on a drive up ramp, so I lowered the front. Worked like a champ.
07-23-2015, 08:03 PM
I added the husky foldup foot thingy and can really raise the front... X2 what OC said. Crank up the tongue with the foot has not failed me. A ramp extension done right would also work.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
07-23-2015, 08:09 PM
Left Coast
Same problem with race car trailers...cars low, oil pan hangs up.....we add an extension to the door and hinge it so it lays flat against door (on the inside of door). That way it's always there and won't scoot .
07-23-2015, 08:27 PM
Thanks for all the ideas folks. I can raise the front and probably get it out, but what about when I'm set up at a campsite? I can't take it apart every morning and night. I suppose I'll devise some ramps.
07-24-2015, 09:03 AM
I think ramps would be your best bet. Only need two and just make sure where the ramps are position for the rear tires they clear any footpegs or crash bar up front and you should be okay.
I would even go as far as fabbing up some kind of rack to hold them under the trailer to keep them out of the way from inside storage.
07-24-2015, 09:12 AM
94' FLSTHC. I raise the front if I have too. Or on the way in I find a small elevation change I can back up to. Park at night under the loft of the 5er.
07-24-2015, 12:40 PM
Had the same problem. Ramps or boards work well. I carry 2 2x8's, 6 ft. long, marked the positions on the ramp door, cheap and works great. Made a rack under the 5er to store them. Once the trike is out, it stays out under the front of the overhang.
07-24-2015, 12:45 PM
Georgia Rally Coordinator
I'd just buy the aluminum ramps from Lowe's set partially on ramp door rest out toward the end and off ramp. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-24-2015, 01:13 PM
I have an XLR 30 fqsl and a Harley with pipes that dig in when exiting the ramp. My high tech solution after beating up my aftermarket pipes (you just can't come off slow enough!) was to place 2 - 2x8 blocks under the round bumper pads on the outside of the door. I still don't like that the "nonslip door surface will not let me use my front brake to keep things at an acceptable exit speed, as I don't need the pads when i drive UP the ramp! Try barely getting on the ramp and then immediately backing down to check how much clearance you create this way. Your trike may have different needs than my Ultra.
2015 XLR 30FQSL
2010 Dodge 2500 6.7 Cummings
2003 H-D Ultra Classic
40 days out 2018
Illegitmi Non Carborundum
07-24-2015, 02:01 PM
Two of these and you are good to go Tri-Leveler - $14.75
I had the same problem with my Tri-Glide dragging pipes going in and getting stuck in the dirt coming out.
