Old 07-23-2015, 03:33 PM   #1
Ramp too steep for my new trike
I hope to get some wisdom from the gurus on the site. I have a 2014 XLR27HFS. I just purchased a Harley freewheeler trike and found that I can get it up the ramp but cannot get it down the ramp. The pipes will bury themselves in the dirt backing down the ramp. How can I get less of an angle on the ramp so that my pipes will clear the ground as I go up and down? It's the ground to ramp angle and not the hinge angle that's the problem. Thank for any wisdom.
breezyhillfarm is offline   Reply With Quote
Old 07-23-2015, 03:35 PM   #2
wyo700's Avatar
Can you back in? If not may have to come up with something where you can have the ramp off the ground a little.
2012 Sandstorm 203SLC
2013 Toyota Tundra Crewmax 5.7
2014 Honda Pioneer 700-4
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-23-2015, 03:36 PM   #3
It has a "starter motor" reverse, which is designed for getting out of a parking space and that's about it.
Old 07-23-2015, 03:38 PM   #4
oldgold's Avatar
Add a speed bump on the ramp. Look up quote #77 on the thread "what did you do to your Hyperlite XLR today" under the XLR category. WolfWhistle has a great explanation.
You could take what he posted and maybe apply to the bottom of the ramp.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 07-23-2015, 03:42 PM   #5
Thanks oldgold. That post seemed to be about the hinge angle unless I read it wrong. My problem is the ramp is too steep at the ground.
Old 07-23-2015, 03:44 PM   #6
Raise the front of the trailer?
Old 07-23-2015, 03:46 PM   #7
Fulltime family RVer
Can you get make a triangular wedge to raise/extend the end of the ramp? That seems like it should lessen the angle from ground to ramp. Not sure how long it would have to be, though.
ependydad is online now   Reply With Quote
Old 07-23-2015, 03:47 PM   #8
Pauls Toy Hauler's Avatar
just throwing it out there but what about getting some aluminum ramps like those used to put bikes in the back of trucks and then placing those behind the rear wheels on the ramp before it comes to the end. could probably even find a way to quick release them on the ramp.
I don't have an XLR but wife says her heart skips a beat every time I load my Road Glide into the back of my 351-THSS because she has measured that my rear fender comes within 2 inches off the ground.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 07-23-2015, 03:48 PM   #9
oldgold's Avatar
Put the speed bump on the bottom of the ramp so your back end raises while the front end comes down the ramp some. It should prob be enough for the pipes to clear.
It may only take a 2x8 laid across at the bottom.
Old 07-23-2015, 04:40 PM   #10
Also just thought that I only need two ramps for the rears as the front coming down in the middle would raise the back end, right?
