Old 12-03-2015, 10:48 AM   #1
Really like the 29HFS - couple of questions
I have been doing a lot of internet browsing on the TH subject. One main constraint I have is the overall height of the unit. I have covered storge at my house for 12'. Been looking hard at the WNP models and they will work but it looks like the Hyper Lite line of bumper pulls are relatively low at 11'2" give or take. The 29 HFS has really caught my eye. A couple of questions.
1. what is the side wall construction method?
2. With the slide all the way closed and you still walk by / open fridge
3. Prob dumb but - can the slide be open part way? manually?
4. ceiling height inside the unit?
TV will be a 2500 6.7 CD 4x4 - Also have a '15 Tundra CM 4X4 (wifes) but looks like the poor Tundra due to it's payload limitation won't have the cap to tow most of the units I am interested in - bummer
TXsurfer is offline   Reply With Quote
Old 12-03-2015, 10:59 AM   #2
I can't answer most of your questions but can tell you that your slide can be stopped at any point on the way in or out. I'm sure the others will be along soon to help on your other queries.
Karl4Cat is offline   Reply With Quote
Old 12-03-2015, 05:02 PM   #3
John513
JohnRiordan's Avatar
Yes still get to fridge with slide in and never paid attention to ceiling height. I'm 6'1" and plenty of room, just watch the pass thru doors as they are only couple inches above my head. Side walls are aluminium framed with fiberglass outside and foam in between inside and out.
JohnRiordan is offline   Reply With Quote
Old 12-03-2015, 07:29 PM   #4
Play Harder's Avatar
29hfs is fully usable with slide In only access blocked is slide side bedroom door - but you can access bed room thru other door and a couple cabinets blocked off when slide in - others wise fridge, stove seating garage access is all good to go ---
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 12-04-2015, 04:33 AM   #5
WolfWhistle's Avatar
Questions already answered but would add... Outside wall are a ridged laminated fiberglass or philon (sp?) outside with vinyl wall covering on 1/8" luan plywood inside... very thin gauge aluminum frame structure filled with foam; about 1-1/4" thick but surprisingly strong I might add.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 12-04-2015, 10:10 AM   #6
well after discussing with the wife and she is correct the sep garage space will not work for us because our toys are too long.. ( kayaks & paddle boards ). Back to the WNP models.. thanks for all your advice though..
Old 12-04-2015, 01:27 PM   #7
I don't know how big they are, would they fit on a ladder rack?
WW
Old 12-04-2015, 04:50 PM   #8
Homebrew's Avatar
There is a Thunderbolt model with a 14' &16' garage!
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 12-04-2015, 05:41 PM   #9
Then he'd need a new truck too. Now, to some that's an exciting proposition. Others, not so much...lol...
Old 12-04-2015, 05:45 PM   #10
Homebrew's Avatar
Once the wife see it the gears will be turning! That's how I got a new truck & TH. LOL !
2014 Ram 3500 DRW
