Old 05-17-2015, 04:57 PM   #1
rear Bunk riser
My electric bunk will not go u or down. any ideas.
jcr8on is offline   Reply With Quote
Old 05-17-2015, 07:41 PM   #2
Does the motor make noise at all? Fuse? We need more details.
breezyhillfarm is offline   Reply With Quote
Old 05-18-2015, 07:36 AM   #3
WolfWhistle's Avatar
What B said (30 amp fuse), it is pinned in place. Checking to see if plugged in is an easy check (lot easier if down
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-18-2015, 09:06 AM   #4
Play Harder's Avatar
There is a good trouble shoot guide in the back of the manual for your system
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 05-20-2015, 04:30 AM   #5
when you press the button you don't hear any relays click and the motors don't make any sound. it appears to be a loss of power issue. I checked the fuses with a meter and they are all good. is there a cut off switch I don't know about?
wcr8on is offline   Reply With Quote
Old 05-20-2015, 02:33 PM   #6
XLR Production
What model do you have???
bulletbob is offline   Reply With Quote
Old 05-20-2015, 03:04 PM   #7
29 foot hyper lite xlr
Old 05-20-2015, 07:21 PM   #8
XLR Production
On the ceiling just above the motor is the brain, there are two red plugs, unplug them and turn them over. Some times that works. Next to the brain you will see a hole in the ceiling panel with wires passing through it. Pull the wires out of the hole and make sure the two connections are tight. You also have limit switches on the curb side rear leg. Make sure nothing has fallen inside the leg assembly and tripped it. Also on the brain and the wall switch is a phone cord. Make sure that it is plugged in as well. Hope this helps
Old 06-03-2015, 03:50 AM   #9
RooVader's Avatar
This happened in my 24 several times as pillows would bump that red plug going into the motor. It was tough to reach but a slight wiggle and it would be right back working.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 06-05-2015, 06:13 AM   #10
Steve38's Avatar
Check the extra mounting point for the second bed. It slides up and down inside the track. If i remember it is the rear track on the right. If it is stuck and cannot move down it has stopped on the stop switch. Just move it and try a spray lube on it.
Steve38 is offline   Reply With Quote
