Old 06-29-2015, 12:43 PM   #11
7 Year Class A RV'er
With its proximity to the city water versus tank switch, I would tend to lean towards it being a second water pump switch. In the Legacy, there's a water pump switch on the water control panel as well as one inside the coach with all the other controls. I would expect tank heaters inside so you could turn them on if needed without going outside. If you flip it on, do you year the pump pressurize?
2015 Legacy SR340 360RB
Old 06-29-2015, 12:52 PM   #12
I believe the switch your referring to in the bathroom is the fuel pump switch.
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
dennismo is offline   Reply With Quote
Old 06-29-2015, 12:53 PM   #13
With all the wonderful replies here and some emails to the dealer. The outside Red Switch should be a second water pump switch. I will
test/listen for the pump to come on when I fill the fresh tank again. As for the second switch in the bathroom next to the light switch. This should be the tank heater. I will confirm this as well via the "flyer" that came with all the manuals. Just was not thinking about using the tank heater when I have the AC on...
Once again....thank you everyone for the replies.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is online now   Reply With Quote
Old 06-29-2015, 01:07 PM   #14
WolfWhistle's Avatar
I don't have the extreme package my switches in the bathroom are... the light... the water heater and the water pump ... The fuel pump switch inside is next to the exhaust fan switch... On mine
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-29-2015, 01:57 PM   #15
Play Harder's Avatar
I have extreme package - the switch in picture is second water pump switch and the second switch in bathroom next to light switch is the heated tanks switch that only activates if the outside temp is below 40
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 06-29-2015, 02:12 PM   #16
PH
Thank you for the info...
Old 08-10-2015, 12:57 PM   #17
What would be the purpose of a secondary water pump?
newtorv22 is offline   Reply With Quote
Old 08-10-2015, 01:00 PM   #18
Not a second water pump, just a second switch for the one water pump. Allows you to turn on the pump from either inside or outside the RV.
Old 08-10-2015, 03:19 PM   #19
That makes more sense I guess. Thanks.
Old 08-12-2015, 04:35 PM   #20
I switched mine on yesterday and got nothing. I couldn't hear it pressurizing or doing anything.
black
