Old 08-13-2015, 10:40 AM   #21
WolfWhistle's Avatar
Is it just me or does anyone else wonder why odd or unique switch(es) are not labeled from the factory??
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-13-2015, 04:07 PM   #22
I agree with you WW. They all should have a temporary label from the factory. Or at the very least be explained in the manual.
newtorv22 is offline   Reply With Quote
Old 08-14-2015, 07:02 AM   #23
I plan on testing this out the next time I actually use the fresh water tank. Going camping this weekend but I will have "city water" from the campground we will be at.
There are a few switches that aren't labeled (i.e. water tank heater) that would help customers. Can't always depend on the dealer or manuals...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 08-14-2015, 11:53 PM   #24
Play Harder's Avatar
Yep agree w labels - and the un useful order they put the switches in - I've had to reorganize all switches so they make sense IE-- entrance 2 switch -main lights awning LED -4 switch in kitchen order -LED light, inside mood led, outside mood stair lights, Fuel pump - 4 switch in bathroom - bathroom lights, water pump, hot water heater, heated tanks --garage 4switch - garage light, fan, back outside light, side outside lights, outside in water fill Cubey - water pump switch and a switch that is a light --
This the order the switches are now after I rearranged them 2016 XLR HyperLight 29 HFS
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 08-15-2015, 08:27 AM   #25
And not real fond of the slide switch right by the door...have hit it a couple of times when walking in and trying to turn the lights on.
DennisTD is offline   Reply With Quote
Old 08-15-2015, 12:25 PM   #26
So I got looking at the switch and mine is stamped pump switch in little letters I switched it on/off a few times and with the inside switch on/ off and never got anything I'm going to call the factory rep and ask. I'll post my results here!
Old 08-15-2015, 12:39 PM   #27
Did you leave a faucet on to see if water would run or not- just asking - my pump makes no noise when I turn it on or off only when water is running
Old 08-17-2015, 05:43 PM   #28
I did not, I'll do that tonight when I get off work.
Old 08-19-2015, 09:23 PM   #29
northstar1960's Avatar
Ditto on that
northstar1960 is offline   Reply With Quote
Old 08-19-2015, 10:06 PM   #30
So I tried this tonight. With the water pump switch off inside, I took my outside shower hose connected it and turned the switch everyone is wondering what it does and it did turn on water pump! So know we know what it does
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
dennismo is offline   Reply With Quote
black
