Old 04-15-2015, 03:40 PM   #1
Refrigerator drain tube
2014 thunderbolt xlr 395 amp
macash is offline   Reply With Quote
Old 04-15-2015, 03:45 PM   #2
Fulltime family RVer
We don't charge by the word but do need more information on what you need help with.
ependydad is online now   Reply With Quote
Old 04-15-2015, 03:46 PM   #3
BamaBob's Avatar
OK and your question is?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-15-2015, 03:47 PM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-15-2015, 03:47 PM   #5
Ok, messed this up again....not familiar with how to reply...my refrigerator is not draining properly. I have to put a towel underneath the drip pan hole. Took off the grate to see if the tube leading out of the fridge was plugged and there was nothing. Am I missing something on this? There was not a drain tube to be found that I could clear or anything. Any thoughts or suggestions. When the fridge goes into thaw cycle all the water goes into the bottom of the fridge. Thanks.
Old 04-15-2015, 03:48 PM   #6
oxcamper's Avatar
Seriously guys, he's a new poster and I've done the same thing too.
So what do you want to say?
Old 04-15-2015, 03:52 PM   #7
oxcamper's Avatar
The drip tray under the cooling fins has a tube which leads to the drain tube outside. If there's no tube from your drip pan, then yes, you are missing something. Do you have a tube on the outside of your trailer, usually coming out of one of the fins at the back of the fridge?
Old 04-15-2015, 04:04 PM   #8
Tx for the reply...checked out thoroughly...nothing. can't see even a little hole where it may have been. Trying to find a thin bendable type of plastic or something like that to run thru the hole...maybe that's all I can do to see if it comes out anywhere...ha..Any other suggestions maybe?.
Old 04-15-2015, 04:17 PM   #9
fonzie's Avatar
This might help......
Fonzie
Old 04-15-2015, 04:18 PM   #10
Flybob's Avatar
There should be a tube from the grip tray outlet on the back ( outside ) of the fridge. It should be routed through the outside fridge vent.(see photo) You can use any tubing, but be sure to put a screen in the end to prevent the entrance of critters
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
drain, refrigerator
