Old 05-24-2015, 01:17 PM   #1
Refrigerator quit working
My fridge quit working on gas or electric. Worked fine last weekend. Will call for warranty Tuesday but looking for thoughts of stuff to check. Gas is full. Electric is on. Tried auto and gas only. Restart few times. Checked some fuses in outside access panel ?
2015 29 hfs / 06 gmc 2500hd
lonb is offline   Reply With Quote
Old 05-24-2015, 08:45 PM   #2
67cudafb's Avatar
Make sure your battery is up to snuff!
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
Old 05-24-2015, 09:04 PM   #3
Herk7769's Avatar
When you press the "on" button, does the "auto" light come on?
You must have a good 12 volt (fully charged) battery or a working converter to power the fridge even when on shore power.
If the AUTO light is on; next stop is under the outside panel. Look for a black plastic box. There are two long fuses in there, one for AC and one for DC/GAS.
Also check the stack overtemp sensor. If it has popped; push it back in.
Name:	913th 3rd Annual Picnic and Camper photos 031.jpg
ID:	77941   Click image for larger version
ID:	77942   Click image for larger version
Name:	Camper Fridge 001.jpg
ID:	77943   Click image for larger version
Name:	Camper Fridge 007.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-25-2015, 05:44 AM   #4
Batteries are good but I'm going to check stack sensor. Looked at fuses there good
Old 05-25-2015, 10:12 PM   #5
We had the same problem last month with ours. The refrigerator would come on in either gas or electric but would never cool. You could even hear the electric cooling fans kick in after enough heat was built up. I tried everything I could while camping, turned off for several days, unplugged 120 volt, disconnected 12 volt with nothing working. Took it to the dealership a couple of weeks later and it has worked fine since.
the.wilsons is offline   Reply With Quote
Old 05-26-2015, 04:56 AM   #6
What did they fix. Or did it fix itself until it's out of warranty(haha). I hope we find a bad part otherwise she won't trust it. Had to go get coolers and ice for food. And I all ready had five coolers home
Old 05-26-2015, 06:26 AM   #7
Taranwanderer's Avatar
We had the same problem with our fridge in our (new) unit last year when we bought it. Took it back to the dealer and had them replace the whole fridge. I'd insist on it. My wife did, and she can be very persuasive... I think they got a bad batch of fridges from Dometic at some point.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-20-2015, 06:13 AM   #8
Picked up my th from the dealer. They said there was a air bubble in ammonia line ? Took fridge out turned upside down for a few minutes then right side up let everything settle and it works now. Any thoughts
Old 06-20-2015, 06:25 AM   #9
Our 2015 Avenger had a bad cooling unit which was promptly replaced under warranty. The service technician suggested Dometic manufactured a bad batch.
ehnolan is offline   Reply With Quote
Old 06-20-2015, 06:51 AM   #10
Herk7769's Avatar
This can happen when you operate the unit out of level.
Evaporative cooling requires a level platform for the liquid ammonia to return smoothly to the reservoir. Good thing you got this fixed. The next stop was a cracked boiler and loss of coolant from overheating.
Old 06-20-2015, 04:13 PM   #11
WolfWhistle's Avatar
Good information Herk. I'm going out to write down the fuse numbers and stock a few... just as soon as it cools off.. its 102 here now... nope just popped up to 103. I've already been drenched earlier... washed truck and camper; shirt and shorts couldn't have been wetter if I had jumped into a pool.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
fridge, refrigerator
