Old 03-10-2015, 09:38 PM   #11
northstar1960's Avatar
What are people doing for a air compressor ? I've been looking at the 3 gal 1 hp 9.5 amp 125 psi 43 lbs husky . I see they replaced the plastic oil site glass with a for real glass one , the oil less are too noisy
northstar1960 is offline   Reply With Quote
Old 03-10-2015, 11:11 PM   #12
Play Harder's Avatar
Some of buds are using the remote start powerhouse PH2100pri if you search they start at 599 and up pretty close to the Honda Db levels and you can parallel too..... W a remote controller key fob remote control start feature - lightweight too
Get out and Play Harder😛
2015 XLR Hyper Lite 29hsf - loaded on order
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 03-10-2015, 11:13 PM   #13
LED comment was more for the masses - replace your lights folks w led light u will be amazed how long your batteries will last😀
2008 Can Am Spyder
Old 03-10-2015, 11:17 PM   #14
B and B's Avatar
I just Bought a 4000 watt PowerHouse. Electric Start, Remote start, Fuel Injection and almost 9 hours at full load. I ran this at -20 C and it worked like a champ. Running Premium in it, 5W30 Synthetic Oil.
PH4000Ri/E | Powerhouse Generators
Get this, I paid $1400.00 Canadian at the Toronto RV Show. Best deal out there.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-11-2015, 12:15 AM   #15
2008 Can Am Spyder
I've seen the ph 3100 remote start could not find a 2100 w remote start . the 3100 compared to the champion 3100 is a couple hundred more
Old 03-11-2015, 12:25 AM   #16
looks like a good unit . didn't read any reviews on it yet . it is considerable louder then a honda 3000 at 48/58 db and the PH is 58 /69 that equates to almost twice as loud . The more i look into it i think I'm becoming penny wise and pound foolish , spend a 1000 now and end up down the road with an onan and a used generator i will need to sale or maybe just bite the bullet and get the onan spend the 2900 and be done with it . since it would have a 30 gallon fuel tank to draw off of and db levels very low for a 4000 68 at 10' where most others say 68db at 23' . I just may have to cough up the dough
Old 03-11-2015, 12:40 AM   #17
was just reading about the power house gens seems the 2100 does come with remote start . What stood out was it says to shut off remotes switch at unit and fuel when shutting off . what good is a remote start if you have to go out and shut the remote switch off and the fuel . makes no sense . that would mean you would have to go out in the cold morning turn on the fuel flip the remote start switch on the unit . then go back in side and use the remote .lmao
Old 03-11-2015, 08:50 AM   #18
WolfWhistle's Avatar
LED comment was more for the masses - replace your lights folks w led light u will be amazed how long your batteries will last��
Get out and Play Harder��
2008 Can Am Spyder
x2 PH.
A simple comparison when replacing with LEDs. With only two incandescent lights on (4 bulbs) this load caused the fan in the 30amp converter run, where 8 lights (16 bulbs) no fan. I know this isn't very scientific, but that told me something.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-11-2015, 09:09 AM   #19
The impression I got was if you don't run it for awhile, or store it, shut if off completely... so the battery doesn't run down.
I think your gut is right about the Onan and doing it right. The convenience and quality is the way to go, if you can swing it financially. Probably not the place to pinch pennies.
Old 03-11-2015, 10:53 AM   #20
Yep just need to sale some more stuff i don't need . the 2 big expenses now is the onan and a kawasaki klr 650 to replace my atv which i sold last week .
the onan is the way to go really . why pay 2200 for 2 honds when for less then 700 more you can get the onan and be done
generator
