Old 10-09-2016, 08:55 PM   #1
Rim Air Pressure Rating
Hi All! I'll try to make this short and to the point. A friend has a 2015 29UDQL5 and wants to upgrade his tires to the Goodyear G614's. He pulled one of this wheels off today and looked to see if the rim air pressure was marked on the rim and the only rating on it was the load rating at 5950# (If my memory is correct). They are 8 lug alloy wheels. He is going to change the valve stems to metal and has a TPMS. So, in saying all that, How does someone find out the air pressure rating or does he just upgrade to the new tires and stay within the load rating?
TIA for your INFO and Time.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 10-10-2016, 06:41 AM   #2
Head Rambler
I spoke with a wheel mfg. a while back and was told that they don't have a psi rating on the wheels. They will handle any tire pressure requirement up to the rated load.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-10-2016, 09:56 AM   #3
Airdale's Avatar
The GY G614 requires a high pressure (110 psi) rim with steel bolt in valve stems. It's size is 16x6.5". That 6.5" rim width is the only width approved by GY.
Here is a reference.
TR8 | Sendel Wheels
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 10-10-2016, 10:20 AM   #4
Fulltime family RVer
That's one thing I like about the Sailun S637. It comes in a 6" width.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 10-10-2016, 01:34 PM   #5
Airdale's Avatar
Which one are you talking about?
Sailun Commercial Truck Tires: S637 Regional All-Position
USN - RET
DOD - RET
SSA - RET
Old 10-10-2016, 01:58 PM   #6
You're right, I misspoke. I meant: ST235/80R16 but see that I'm wrong.
Old 10-10-2016, 02:33 PM   #7
hdmtnrider, can you double check with you friend and see if the load rating on the wheels are 5950#. If they are see if he can take a photos of the wheels I need to but 6 for my trailer as I had 1 3750# wheel fail last week. TIA
2015 Ram Mega 3500 DRW, 2016 Vengeance 377V
boatman22 is offline   Reply With Quote
Old 10-10-2016, 04:03 PM   #8
Airdale's Avatar
It may be marked on the rim somewhere, inside or outside. When all else fails call/email the rim manufacture.
USN - RET
DOD - RET
SSA - RET
Old 10-10-2016, 07:33 PM   #9
Taranwanderer's Avatar
I seem to remember a post a long time ago, possibly from one of the factory guys on here, that the XLRs all use the same high pressure rim, regardless of which tires are mounted on it. Not 100% certain, but maybe we could get a confirmation on that from BulletBob?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 0
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-10-2016, 07:49 PM   #10
Usually Confused Member
emm-dee's Avatar
Define fail, please. A leak or did it disintegrate?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
pressure
