Old 07-15-2015, 12:25 PM   #1
sanitizing a fresh water tank
When sanitizing a fresh water tank, how do I get the water and the solution to go into the fresh water tank? The inlet does not allow you to "pour" anything into the tank.
efgentry1 is offline   Reply With Quote
Old 07-15-2015, 01:11 PM   #2
Fulltime family RVer
I pour the solution into the empty hose first, then put the hose in the inlet, and then turn on water.
ependydad is online now   Reply With Quote
Old 07-15-2015, 01:13 PM   #3
I was going to use a transfer pump like this one with a clean 5 gallon bucket of bleach and water mix https://www.waynepumps.com/sites/def...%20Branded.jpg
Berjr1 is offline   Reply With Quote
Old 07-15-2015, 01:22 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
If you can put a hose in the inlet how come not a funnel to add your bleach? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-15-2015, 05:18 PM   #5
WolfWhistle's Avatar
X2 adding to empty hose ... Then attach hose and turn on water.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-15-2015, 05:42 PM   #6
aceinspp's Avatar
If your filling the FRT with the hose then one can just add bleach using a funnel then connect water hose to fill. Sounds like you are making a project out of this. Enlighten me, maybe I'm missing something here. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-15-2015, 06:57 PM   #7
Homebrew's Avatar
You need to have a pressurized system to push the bleach into the Fresh water tank. A funnel will not work.
Filling a hose with bleach 1st and connecting to trailer works as long as you have pressurized water pushing the bleach.
If your buying a pump get the Wayne 12v type so you can fill your tank during dry camping.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 07-16-2015, 12:03 PM   #8
X2 with a funnel. I always just pour it in. I don't understand why you would need a pressurized system to push the bleach into the FRT. Gravity gets the job done from the fill tube.
Dan Sundt is offline   Reply With Quote
Old 07-16-2015, 12:03 PM   #9
Dave Lyon's Avatar
I use a watering can that i bought specifically for this task. Mix up your solution ans pour it into the inlet - then fill up the tank with your white RV hose.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 07-16-2015, 12:17 PM   #10
mike.t's Avatar
Mix the bleach in a bucket put a funnel in the inlet pour the mixture in the funnel. I may be missing something here as well.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
fresh water, tank, water, water tank
