Old 09-24-2014, 07:38 PM   #1
Gustavomontoya's Avatar
Shower door on 29hfs?
Has anyone installed or replaced curtain with shower door on the 29hfs hyperlite?
Gustavomontoya is offline   Reply With Quote
Old 09-25-2014, 07:06 AM   #2
Sunseeker 2500TS
Not a bad idea, I would like one too. I'll have to search the web for that one.
rocrider50 is offline   Reply With Quote
Old 09-26-2014, 03:46 PM   #3
WolfWhistle's Avatar
Hey G, have you considered this: the opening wall to wall, is slightly less than 36", if the door slides a full half of this, the opening would be 18". I might fit through it now, but some might no. Plus it won't curve out, like the factory shower curtain rod. I just ordered the Extend-A-Shower rod, since so many rave about it.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 09-29-2014, 11:02 PM   #4
Sturgie's Avatar
My 27HFS, which have the same bathroom size as you, came with an accordion style shower door. Way too small, so I installed a curved shower curtain rod. Much roomier and appealing looking with the liner and outer curtain to match as well
Sturgie is offline   Reply With Quote
Old 09-30-2014, 05:01 PM   #5
Sturgie, do u have a picture of that setup, and how do you keep the floor from getting all wet
Old 09-30-2014, 05:08 PM   #6
Sturgie's Avatar
I'll get one this evening
Old 09-30-2014, 05:09 PM   #7
Cool. Thank you
Old 10-01-2014, 07:46 AM   #8
Sturgie's Avatar
Late night last night working. Didn't get a chance to take some pics, but will be able to post them this evening.
Sturge
Old 10-01-2014, 08:43 AM   #9
Have you guys seen Extend-A-Shower? Its made by Stromberg Carlson. Besides extending out, it also flips inside the same amount, so the curtain hangs way inside the tub. The curtain rod my unit came with causes the shower curtain to hang out and interfere with the toilet. They make them in several finishes and in two lengths. I found what I think is the best deal from CW because of the free shippping. BTW, SC makes a lot of RV accessories.
Extend-A-Shower :: Stromberg Carlson
Hyper Lite was sold
Old 10-03-2014, 05:32 PM   #10
Sturgie's Avatar
Sorry tht took so long to post. This works great for us. I had to trim the curtains just right, both length and width. I think I have 8 rings on the rod. The corner water stops were from Home Depot.Click image for larger version
Name:	ImageUploadedByForest River Forums1412375291.162948.jpg
ID:	64059Click image for larger version
Name:	ImageUploadedByForest River Forums1412375319.557210.jpg
ID:	64060Click image for larger version
Name:	ImageUploadedByForest River Forums1412375345.037339.jpg
Old 10-04-2014, 09:14 AM   #11
That's great. Thank you
Old 10-04-2014, 09:28 AM   #12
Sturgie's Avatar
Yes the curtain is tight behind the toilet, but just the outer curtain is. I read a post from a member that put the toilet on a 45 degree angle for more room; and I plan on doing tht soon
Old 10-04-2014, 03:03 PM   #13
Like the water stops!
Hyper Lite was sold
Old 10-06-2014, 09:37 PM   #14
Kilday4's Avatar
Very nice mod. Water stops are definitely going to be a must.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
door, show, shower
