Part #1
This is a post I put up in the beginning of July.
Smell From Sewer & Fresh Water Odor
Going all the way back to last year my first trip to Tennessee. We detected that terrible odor. I then did my research and somewhere on the forum someone said the Grey water needed lemon tablets. I tried that and it went away or so I thought. A little more research revealed pee traps needed to have water in them to prevent odor from coming back up through the pipes. I did that and it went away for awhile but returned on several other trips. So, I'm down to the last thing that I think can be done. The 360 Siphon's that I see so many reviews on and youtube
https://youtu.be/CVcwc28PinQ . My next camping trip will be in Sept as scheduled so I have time to fix it before that trip. BUT BUT i wanted to share something with everyone that we did on July the fourth. The smell was in my camper and OMG what am I going to do. Being I'm in construction I'm always thinking. Well this is what I done and believe it or not solved a problem (Now we'll call it a temporary Camping trip solution but you'll have to do it again and again but I found it to work. I turned the water off, open the toilet opening and stuck my leaf blower on low to blow air into the tank and out the vent. Guess what It work no more odor. I did this for a about 10 minutes. The odor was gone. So our week at the lake was wonderful.
Test #2:
I'm home and figure I needed to repeat the process again. This time I open the toilet value and set a counter fan same size a toilet and turned on low. Stepped out side and OMG there was that stink smell it was blowing out the vent. After a few minutes the smell was gone.
Test #3:
Now the gray water. Being I have two tanks I cleaned them out very well while at the camp site. I went to Walmart and bought me another connection (Clear) and hooked my swimming pool hose to it about six foot and connected it to my shop vacuum. Turned it on with gray water valves in open position. Within a few minutes that smell was gone.
So all I have to do now it purchase and install those new 360 Siphons. And even after I install these I'll probably still use the fan method each time I camp to assure myself I have filled the tank with quality outside air.
Anyway thought I would share my new idea and you can try itself and no expense.
Part #2
1. I installed new 360 Siphon's on Gray Water #1, Gray Water #2, Black Water #3. Prior to camping the night before I open the toilet trap door and I have a fan that blowed all night and clears that sewer odor.
2. I have NOT had any more odors inside or out.
3. I bought a three inch fan from walmart just big enough that I could sit it inside of the opening of the toilet door.
4. My sewer odors are now gone.
Note: Back in June just before my July 4th camping trip. I purposely filled my Fresh water tank, Gray Water tank #1, and Gray Water tank. Filled until water backed up in sink and in shower. I let sit for three days. I was able to determing most of smell comes from your black water tank, or in my case my black water tank. Took me awhile to figure it out but I have solve my issue with stinking odors.
Tim Coltrain in the Wonderful state of North Carolina.
