Old 02-03-2013, 09:21 PM   #21
We have 6-point auto leveler - but if site is more than a bit off level to one side or the other, I will drop a 2x8 under the low side (or two if really bad) and put an extra layer of cribing under the pads. The hit the auto level button after moving the truck out.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-03-2013, 09:32 PM   #22
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by DAISY BOYKIN View Post
First thing I do is park on level ground!
But if all else fails, I use a 2" X 8" X 3 1/2 ' board, If that fails, I use the plastic leveling blocks as stated above.
The 2" X 8" is mitered (Tapered) on each end for easy roll on.
x2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-03-2013, 10:14 PM   #23
Herk7769's Avatar
I use the "Lego" blocks and carry two sets with caps. However I only use them without wood under them when on concrete pads.
I found that on grass or gravel, they sink into the ground or break.
I carry several 2x10x12 pieces of pressure treated wood to build a base for the "Lego" blocks if I need to lift more than 1.5 inches.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-04-2013, 09:35 AM   #24
SYE
SYE's Avatar
That's probably why I keep breaking mine when they sink into the grass. I was wondering cause they are rated at 30k pounds.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 02-04-2013, 10:41 AM   #25
Herk7769's Avatar
Yes, but they ARE plastic and can be broken when that weight is on sharp gravel. I also lost a few when it sunk into the soft thawed grass; then froze hard into the ground when we had to leave the next day. The soft dirt had worked its way into the honeycomb structure.
Could not wait till spring to recover them. The 30k is on a hard surface.
Old 02-04-2013, 10:52 AM   #26
SYE
SYE's Avatar
That's about the same with me, I like them cause they are easy to store. Oh well when I break them all I will buy more.
Scott & Vicki
2021 4 reserved
Old 02-04-2013, 10:58 AM   #27
Always Learning
I keep a combination of wood and lego blocks. I did have one time that they sunk in soft ground and were a hassle to retrieve. I'll be more aware and put wood under them when it seems like it might be needed.
Old 02-04-2013, 11:00 AM   #28
SYE
SYE's Avatar
I need to need to buy a 2x10 and cut it
Scott & Vicki
2021 4 reserved
Old 02-04-2013, 11:55 AM   #29
Wanna Be Camper
SaskCampers's Avatar
Carry 3 2x10's and a couple 1x10's plus my home made blocks for under the stabilizers so I don't have to extend them as far keeping the unit more stable. US border guard in Michigan actually asked me if there was anything in the blocks when he saw them and when I told him what they were for thought it was a good idea.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 02-04-2013, 06:01 PM   #30
07 ThunderRoad's Avatar
Originally Posted by Earth Station View Post
I drop the legs.... unhitch and then hit the button that says auto-level!!!
you got that right driver. have fun with the blocks and wood and things. That dog don't hunt.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 02-04-2013, 08:02 PM   #31
phat phrog stunt crew
i will come over to help get your hydraulic gizmo to go back where it belongs when you want to break camp, but i first have to pick up my wood, blocks and things
dwaynerz is offline   Reply With Quote
Old 02-04-2013, 08:37 PM   #32
I hope you don't hurt your back.
Old 02-05-2013, 05:42 PM   #33
nah, ill bring my electric drill and assorted tools. if i can get a screwdriver or a wrench on it, i can take it apart
Old 02-05-2013, 10:10 PM   #34
Grape Escape
Not one suggestion of letting the air out of the high side tires?
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 02-05-2013, 10:57 PM   #35
DITTO!!! Prior to, I would use the interlocking blocks to level. I would actually wiggle around within my site to find the closest to level spot I could find. Steve
sdagro is offline   Reply With Quote
Old 02-05-2013, 11:02 PM   #36
jimh's Avatar
i use treated wood under the tires unitl i get level side to side. then i drop the landing gear and adjust one so that both touch the pad (also wood) at the same time when locked. i have one foot that has a screwed adjustment on it.
jimh is offline   Reply With Quote
Old 02-10-2013, 06:51 PM   #37
JCMINIS's Avatar
This has been a question of mine while we are shopping for a TH. 99% of our camping will be in fields at race tracks (mx and harescrambles). Over the past year at the races with our enclosed cargo, I have paid attention to where I might park such a rig that is even close to level, even arriving early mid friday (race on sunday) it would be tough.
Auto level sounds like the way to go.
JCMINIS is offline   Reply With Quote
Old 02-10-2013, 06:55 PM   #38
TURBS's Avatar
Originally Posted by ttrost65 View Post
I no longer use lumber for leveling, for the simple reason that we often burn it late at night when we run out of firewood.
lmfao
Old 02-10-2013, 07:01 PM   #39
LKicklight's Avatar
Side to Side
Before you pull onto your camping spot, if different every time..I carry an 8'-0 2x4 framing stud...lay it on the ground, place a level in the middle, go to the low or high side....raise the low end to get the your 2x4 level...measure the distance on the end you have raised to the ground...build your boards, blocks whatever to the height..pull your 5'er up on it...should be level from side to side..then I attack the front to rear, which is like any other rv...Have used this system on the T/T and now on the Crusader...
Kicklighter
Dallas, GA.
2011 Crusader 270RET
1003 Sunnybrook 28 T/T
2001 2500HD Ext. Cab 6/0
ID:	24209   Click image for larger version
LKicklight is offline   Reply With Quote
Old 02-10-2013, 10:15 PM   #40
jwwilson's Avatar
Ditto! Big Foot leveling system..
jwwilson is offline   Reply With Quote
5er
