Old 02-03-2013, 09:21 PM   #21
We have 6-point auto leveler - but if site is more than a bit off level to one side or the other, I will drop a 2x8 under the low side (or two if really bad) and put an extra layer of cribing under the pads. The hit the auto level button after moving the truck out.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-03-2013, 09:32 PM   #22
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by DAISY BOYKIN View Post
First thing I do is park on level ground!
But if all else fails, I use a 2" X 8" X 3 1/2 ' board, If that fails, I use the plastic leveling blocks as stated above.
The 2" X 8" is mitered (Tapered) on each end for easy roll on.
x2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-03-2013, 10:14 PM   #23
Herk7769's Avatar
I use the "Lego" blocks and carry two sets with caps. However I only use them without wood under them when on concrete pads.
I found that on grass or gravel, they sink into the ground or break.
I carry several 2x10x12 pieces of pressure treated wood to build a base for the "Lego" blocks if I need to lift more than 1.5 inches.
HAM CALLSIGN - KC3FFW
Old 02-04-2013, 09:35 AM   #24
SYE
SYE's Avatar
That's probably why I keep breaking mine when they sink into the grass. I was wondering cause they are rated at 30k pounds.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 02-04-2013, 10:41 AM   #25
Herk7769's Avatar
Yes, but they ARE plastic and can be broken when that weight is on sharp gravel. I also lost a few when it sunk into the soft thawed grass; then froze hard into the ground when we had to leave the next day. The soft dirt had worked its way into the honeycomb structure.
Could not wait till spring to recover them. The 30k is on a hard surface.
Old 02-04-2013, 10:52 AM   #26
SYE
SYE's Avatar
That's about the same with me, I like them cause they are easy to store. Oh well when I break them all I will buy more.
Scott & Vicki
Old 02-04-2013, 10:58 AM   #27
Fulltime family RVer
I keep a combination of wood and lego blocks. I did have one time that they sunk in soft ground and were a hassle to retrieve. I'll be more aware and put wood under them when it seems like it might be needed.
ependydad is online now   Reply With Quote
Old 02-04-2013, 11:00 AM   #28
SYE
SYE's Avatar
I need to need to buy a 2x10 and cut it
Scott & Vicki
Old 02-04-2013, 11:55 AM   #29
Wanna Be Camper
SaskCampers's Avatar
Carry 3 2x10's and a couple 1x10's plus my home made blocks for under the stabilizers so I don't have to extend them as far keeping the unit more stable. US border guard in Michigan actually asked me if there was anything in the blocks when he saw them and when I told him what they were for thought it was a good idea.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 02-04-2013, 06:01 PM   #30
07 ThunderRoad's Avatar
Originally Posted by Earth Station View Post
I drop the legs.... unhitch and then hit the button that says auto-level!!!
you got that right driver. have fun with the blocks and wood and things. That dog don't hunt.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
5er
