Old 02-04-2013, 07:02 PM   #31
phat phrog stunt crew
have fun with the blocks and wood and things.
i will come over to help get your hydraulic gizmo to go back where it belongs when you want to break camp, but i first have to pick up my wood, blocks and things
dwaynerz is offline   Reply With Quote
Old 02-04-2013, 07:37 PM   #32
07 ThunderRoad's Avatar
I hope you don't hurt your back.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 02-05-2013, 04:42 PM   #33
nah, ill bring my electric drill and assorted tools. if i can get a screwdriver or a wrench on it, i can take it apart
Old 02-05-2013, 09:10 PM   #34
Grape Escape
Not one suggestion of letting the air out of the high side tires?
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 02-05-2013, 09:57 PM   #35
Originally Posted by Earth Station View Post
I drop the legs.... unhitch and then hit the button that says auto-level!!!
DITTO!!! Prior to, I would use the interlocking blocks to level. I would actually wiggle around within my site to find the closest to level spot I could find. Steve
sdagro is offline   Reply With Quote
Old 02-05-2013, 10:02 PM   #36
jimh's Avatar
i use treated wood under the tires unitl i get level side to side. then i drop the landing gear and adjust one so that both touch the pad (also wood) at the same time when locked. i have one foot that has a screwed adjustment on it.
jimh is offline   Reply With Quote
Old 02-10-2013, 05:51 PM   #37
JCMINIS's Avatar
This has been a question of mine while we are shopping for a TH. 99% of our camping will be in fields at race tracks (mx and harescrambles). Over the past year at the races with our enclosed cargo, I have paid attention to where I might park such a rig that is even close to level, even arriving early mid friday (race on sunday) it would be tough.
Auto level sounds like the way to go.
JCMINIS is offline   Reply With Quote
Old 02-10-2013, 05:55 PM   #38
TURBS's Avatar
Originally Posted by ttrost65 View Post
I no longer use lumber for leveling, for the simple reason that we often burn it late at night when we run out of firewood.
lmfao
Old 02-10-2013, 06:01 PM   #39
LKicklight's Avatar
Side to Side
Before you pull onto your camping spot, if different every time..I carry an 8'-0 2x4 framing stud...lay it on the ground, place a level in the middle, go to the low or high side....raise the low end to get the your 2x4 level...measure the distance on the end you have raised to the ground...build your boards, blocks whatever to the height..pull your 5'er up on it...should be level from side to side..then I attack the front to rear, which is like any other rv...Have used this system on the T/T and now on the Crusader...
Kicklighter
Dallas, GA.
2011 Crusader 270RET
1003 Sunnybrook 28 T/T
2001 2500HD Ext. Cab 6/0
ID:	24209   Click image for larger version
LKicklight is offline   Reply With Quote
Old 02-10-2013, 09:15 PM   #40
jwwilson's Avatar
Ditto! Big Foot leveling system..
jwwilson is offline   Reply With Quote
5er
