Old 10-09-2015, 02:32 PM   #31
WolfWhistle's Avatar
OC and Turbs have nice little business going selling poles and brackets. I thought I would make some of these (might need some refinement) and sell them to those lucky individuals with the LCI three handed window locks. A one handed man can work it, or an old man like me can do it with both hands and a lot of embarrassing colorful language.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 10-09-2015, 02:39 PM   #32
Toadman
I have these same windows on either side of my master bedroom slide on my Forest River Cardinal 36-BLE 5th Wheeler. These open and close extremely hard also. WD40 helps for a while, but it appears to be a poor design.
Toadman is offline   Reply With Quote
Old 10-09-2015, 05:25 PM   #33
Play Harder's Avatar
WW yep two locks both sides Click image for larger version
Name:	ImageUploadedByForest River Forums1444429510.038545.jpg
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 10-09-2015, 05:42 PM   #34
Windows hard to open.
Hi all from Calgary Alberta, we bought the V-Lite 30WRKSS 2013. All windows are difficult to open. Once open it isn't too bad getting to full open. Like others closing isn't an issue. Seems that the suggestion of the seal on the bottom rail are the problem makes sense to me. Now that it is fully winterized we'll try some of the lubrication ideas next spring.
dale.flyguy is offline   Reply With Quote
Old 10-09-2015, 06:05 PM   #35
Originally Posted by Play Harder View Post
WW yep two locks both sides Attachment 91090
2008 Can Am Spyder
Aha! Your two lock releases are in a groove, which lets you push the releases while lifting using that groove for "grip". Better design. I need to get a grip!
WWW
Hey, thanks PH for the picture.
Old 10-09-2015, 06:06 PM   #36
#31 above is a joke... nobody's laughing?
WWW
Old 10-09-2015, 06:13 PM   #37
Hi Dale, So some of your windows have the two releases and open vertically? As I slide one of these three windows closed, just before fully closing you can feel resistance... kind of like a seal against another seal. Like the seal is too thick. Someone suggests removing a plastic strip, as well. Which I will look at when I get the TH back. I'm going to find a better to unlock while lifting, but getting bow wax and try that first.
WW
Old 10-09-2015, 06:41 PM   #38
Blaster 84's Avatar
I know of one RV owner that tied a heavy string, or cord, between the two locks. By pulling on the string with one hand he can unlock both locks and he uses the free hand to open the window.
He used this method on a large window with these locks. I would assume it would work just as well on the smaller ones.
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is offline   Reply With Quote
Old 10-09-2015, 07:46 PM   #39
oldgold's Avatar
some windows hard to open? Your's?
WWW
I did think the bobbins were an innovative design.. But your design is lacking.. The force created by the leverage point would be too great already with an up force before there was enough movement on the latch. I'm thinking it would bind up and not release the latch. I think you need to figure out how to accelerate the movement on the latches before up force is applied into the system.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 10-09-2015, 09:06 PM   #40
Scubanut's Avatar
I have three Windows like that, very difficult to open and close. I don't even bother to open them now but if I do I close them from the outside which is much easier.
Scubanut is offline   Reply With Quote
