10-08-2015, 06:23 PM
some windows hard to open? Your's?
I keep wanting to post this and keep forgetting. On my Hyperlite 29HFS, the narrow vertical sliders are near impossible to open. It takes two hands to pull the lock releases towards each other, while trying to pull the window up while seated on a recliner.
Closing isn't an issue. What I do is not close it all the way.. or don't bother to open them.
I just want to know if other's have noticed and/or find them difficult? I've thought about taking off one or both releases and leaving them off. No one larger than a very small child could fit through the window anyway.
Is the lock releases a poor design? Do they expect you to always have a friend, neighbor, or three hands available? What?
Please respond, S'IL VOUS PLAÎT
WWW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
10-08-2015, 06:29 PM
That looks to be the same type window we have on our Forester -- actually two of them -- one in the galley and one in the bedroom -- and they're both difficult. Easier to open the one in the bedroom while lying down!
10-08-2015, 06:45 PM
Try rubbing the track wit a bar of soap it will make them slide easier. Yes they do all slide hard it's usually just at the beginning.
Think about things before you do them make life easier not harder.
10-08-2015, 07:02 PM
Left Coast
2010 Rockwood has the same problem...almost like the window could stand to be a smidge wider to keep the rock out......keep forgett'n to address the things!
10-08-2015, 07:03 PM
WWW
Are these single pane or double pane? Not sure if it matters...just curious.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
10-08-2015, 07:05 PM
Yep, tried 303, silicon, and the soap and its better. Here's what I see (or imagine) is sticking. As the window fully closes; that last 1/2" a horizontal seal on the movable light, slides past a horizontal "seal" on the stationary light and its tight. But the rest of the way up; or down, is okay. It is like theses seals are too thick... at least too thick considering how you have to work the windows. Thanks for the reply Mark.
WW
Hyper Lite was sold
10-08-2015, 07:06 PM
Left Coast
Single
-R.Jones
Nitro 31FQSL
RJ, these are single strength.
WW
Hyper Lite was sold
10-08-2015, 07:09 PM
The TH is at a dealer about the latest AC problem and the issue is on the "to do" list.
WW
Hyper Lite was sold
10-08-2015, 07:13 PM
The only windows I have opened or tried to open are the emergency exits and one like yours in the same place.
I opened the exit windows with due caution to make sure they opened.
The slide window would not budge so I left it closed.
10-08-2015, 10:02 PM
WW mine open easy but are double pane
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
10-08-2015, 11:05 PM
Mine in the bedroom sticks, but I can't check on the single/double pane for a few days. I probably have only tried to open that one bedroom window on the curb side other than the emergency windows as FI did.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
10-09-2015, 06:39 AM
If you can go to a Bass Pro or Cabellas get you a stick of Bow Wax and try that.
I have a stick that I used for my bow and crossbow. I have used it on drawer tracks, sticky windows, boot zippers, etc...
Joy & Mel
2022 XLR Nitro 351
2022 Ram 3500HD MegaCab BigHorn 4x4 6.7L
2020 Indian Roadmaster
10-09-2015, 06:42 AM
WW,
I'm in the same as PH. Easy and double pane...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
10-09-2015, 07:31 AM
Originally Posted by stevejd235
WW,
Steve (PH, too) does the double pane have two lock releases; one on each side that you have to push towards each other, then lift while pushing?
WWW
Hyper Lite was sold
10-09-2015, 07:33 AM
I'll look into that, thanks M. Let you know if it worked. It will be a couple of weeks before I can try it.
WWW
Hyper Lite was sold
10-09-2015, 07:38 AM
That's actually a really good idea. And the best part is I have some already!!! Thanks for the tip.
10-09-2015, 08:02 AM
If the wax don't work, I'm going to have to breakout some stainless steel and make something like this. And, add one to each lock release.
Hyper Lite was sold
10-09-2015, 10:37 AM
Left Coast
Or a come-a-long!
10-09-2015, 11:22 AM
Ours are the same. A pain in the ---. Several years ago at the FROG Rally I asked a FR rep if anyone else had this problem. Not that he knew of, oh well.
VMI'62
