Old 09-12-2016, 08:34 AM   #1
Something broke??
2015 XLR having "issues" with back bathroom toilet. When it is flushed it acts like the bowl water is under pressure (creates a small gyser ), never empties and just keeps filling the bowl. I have plungered (new word. for today) it, with the water on and off; the black water tank is empty; I have snaked it. Still no change. The forward toilet works fine and doesn't seem to be backing up into the back toilet, sink, shower, everything else works. Any suggestions what the problem is and how to fix it???
steath91 is offline   Reply With Quote
Old 09-12-2016, 10:18 AM   #2
Vent plugged
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 09-12-2016, 10:50 AM   #3
Mantisfactory's Avatar
Is the tank full ,Have you drained the tank ,If you have two bathrooms you have two pull stations.
Mantisfactory is offline   Reply With Quote
Old 09-12-2016, 11:07 AM   #4
fonzie's Avatar
Which XLR model do you have?
Fonzie
Old 09-12-2016, 11:41 AM   #5
TURBS's Avatar
Vent pipe may have fallen down into tank.
Old 09-12-2016, 11:43 AM   #6
asquared's Avatar
Stone mountain buildup in the toilet?
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-12-2016, 06:04 PM   #7
Shut the water off, and open the toilet valve and shine a light down there and see if you see anything except the bottom of the tank.
Gotta go campin!
Old 09-12-2016, 06:19 PM   #8
Flybob's Avatar
Do you have two black tanks/ drains? Maybe one was not emptied.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-23-2017, 01:51 AM   #9
Check for a black tank drain between axles/tires
Sent from my SM-G900P using Forest River Forums mobile app
jb4xx is offline   Reply With Quote
Old 01-23-2017, 08:52 AM   #10
Gray tank valve to empty was frozen closed. Finally got warm enough to thaw and now everything is fine.
Old 01-23-2017, 09:26 AM   #11
Glad you figured this out
