Old 06-29-2016, 08:32 AM   #1
Spare/Flat tire prep
Hi Guys,
I just picked up a spare tire for my 29HFS and wanted to see what you guys are doing to prep for a flat. My truck has a jack and I'm bringing a 1/2 in. drive with socket for the wheel removal but wanted to see what you guys are doing. I'm thinking a better bottle jack or even a small roller jack, what have you guys used changing your flat tires?
Craig
Cmill29HFS is offline   Reply With Quote
Old 06-29-2016, 08:40 AM   #2
Ford Idaho's Avatar
I went with a stubby from Lowes.
Short enough to fit under the spring U-bolt with a flat tire but will lift enough to put the spare on.
Electric impact to remove and tighten the lug nuts.
Old 06-29-2016, 08:40 AM   #3
SeaDog's Avatar
You are going to get all sorts of replies that tell you what or what not to do. You are taking the right steps might want to include wood to rest your jack (which ever you use) on. I think you are going in the right direction.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 06-29-2016, 08:43 AM   #4
Play "Make believe" at your Home before you travel! Plan for "Soft ground,sand,unlevel location,and cribbage"! You might encounter the need to crib and start to jack again if the ground is soft! Youroo!!
Old 06-29-2016, 07:20 PM   #5
WolfWhistle's Avatar
Lately I've been carrying the Andersen rapid Jack and 3/4" plywood - 1' x 4" so far, no flats although I did test to see how it works. I used to carry a 10 ton bottle jack but stopped carrying all that wood around. I have Good Sam road side assistance as well.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 07-03-2016, 10:08 PM   #6
Only have had one flat so far and had a 4 way with me. So first I loosened the lugs. Then pull or back up good tire over leveling blocks to raise bad tire off the ground. Take loosened lugs off and put spare tire on. Then back or pull off leveling blocks and tighten lugs down. I do carry a small bottle jack invade it's needed but still haven't used it.
the.wilsons is offline   Reply With Quote
Old 07-03-2016, 10:30 PM   #7
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Look into a TravelAide + if you have multiple axels. Not familiar with your model.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 07-03-2016, 10:32 PM   #8
I think he meant Trailer Aid:
Camco Trailer Aid PLUS, Yellow - Walmart.com
If you get one, make sure it works. It doesn't get you high enough on some TT's.
2011 Traverse LT, 3.6L, FWD
Old 07-03-2016, 10:41 PM   #9
PHS79's Avatar
I have a 4 ton bottle jack and 1/2 inch drive 24" long breaker bar with extension and socket in one of the storage totes. If the tire just happens to be low, I have a on-board air system on my truck and it has come in very handy a couple of times helping others out.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 07-05-2016, 07:56 AM   #10
Taranwanderer's Avatar
Love the TrailerAid. I had to bolt a piece of Trex on the bottom of it to make it tall enough to lift the tire off the ground. Could have used a 2x6, but the Trex was thick enough and is lighter.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 0
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
tire
