Old 07-02-2016, 11:16 PM   #1
Squeaky Fantastic Fan
When my fans are on low or off but moving slowly because of wind. There is annoying squeak. I was planning on using some spray dry lube but was curious what others have used.
Thanks for your thoughts.
2015 XLR Hyperlite 29HFS (installing mods...)
2004 GMC 2500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-02-2016, 11:23 PM   #2
Check the fan shroud for debris that may be causing your abnormal noise. You can gain clear and easy access from the roof with the lid fully open. If you get up there to look, have the fan off and manually spin the blades listening for and noise. Clean the area of any debris.
Old 07-02-2016, 11:25 PM   #3
StillK,
Will do that check. The noise goes away if the blades are spinning fast that is what is werid.
Old 07-18-2016, 10:54 AM   #4
My fan does the same thing. Only at low speed. I have 3 in my 420amp but only 1 makes this noise. Havent looked at a remedy yet
VICSXLR is offline   Reply With Quote
Old 07-18-2016, 01:00 PM   #5
WolfWhistle's Avatar
My maxxair fans don't do this. A seal must be whats doing that? WD40 to the rescue.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 08-06-2016, 02:41 PM   #6
Mine too, squeaked at low speed...I cleaned the blades and inspected - saw no obvious rubbing or debris. It would even squeak when moved by hand an inch or two. Used some silicone spray on the motor shaft and it has gone away. I suspect it is a seal around the shaft.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-12-2016, 11:58 AM   #7
Finally found some time to pop-up off the screens from inside the camper and inspect. Nothing was rubbing, so I did spray some 303 on the motor shaft and the squeaky went away.
Thanks for all the great suggestions everyone...
Old 08-12-2016, 12:48 PM   #8
How tough are those screens? I tried to pop mine off but stopped for fear of snapping the plastic? Seems to be on pretty tight
Old 08-12-2016, 12:54 PM   #9
TURBS's Avatar
Pops right off
Look around the perimeter of screen you'll find a raised portion to pry under.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
TURBS is online now   Reply With Quote
Old 08-12-2016, 01:32 PM   #10
Turbs is right. There is a little "finger" grab part. Pull down on that AND then gently pull down on the screen edge/rim until the first clip releases. The rest of them (~6) will be easy.
fan
