Old 04-05-2015, 07:29 PM   #1
Surge Protector
Just doing some more "shopping" while waiting for the 29HFS to arrive at the end of the month....
It seems the majority of people are using Progressive protectors. If I have done my homework correctly, it looks like I should be ordering the "EMSHW30C" model. By using the hardwired version, I don't have to worry about locking the portable ones. Also, it seems the EMSHW30C model has a "bypass" switch so you can still have power (i.e. unprotected) if the unit has a malfunction.
Looking for any feedback or suggestions from the forum. Also, if anyone has installed one in their 29HFS, I would love to see some pictures as I wait for my 29HFS to arrive....
Thank you in advance for your thoughts.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-05-2015, 07:32 PM   #2
Can't edit the original post to add this link -http://www.amazon.com/Progressive-In.../dp/B0050EGS5W
Old 04-05-2015, 07:41 PM   #3
I went with the 50 amp version of the same unit. Seems to be the best out there and does it all. Will be installing this week.
taken is offline   Reply With Quote
Old 04-05-2015, 07:44 PM   #4
Taken,
Watched a video from the Progressive website about the install. Seems like a 15 minute install once you know where you want to put it...
Old 04-05-2015, 07:48 PM   #5
Yes, not difficult at all. It's on this weeks hit list...
Old 04-05-2015, 07:53 PM   #6
Just for verification, is your understanding that you don't need to have separate plugs on either side of the Progressive to bypass it? I see that Dave961 did this via the picture below. I think with the "bypass" switch on the remote LED, you won't need to have the separate plugs.
Old 04-05-2015, 07:54 PM   #7
It's cheaper then the portable one also.......
2016 Rockwood ROO 233S
2013 Ford F150 3.5 ECO SCREW
TT233S is offline   Reply With Quote
Old 04-05-2015, 07:55 PM   #8
Correct. To bypass, just hit the button. Mine will be buried behind a wall in my basement so no way am I going to go unscrewing and digging to swap it out when the supplied remote and button do it from the comfort of my galley! Just be sure to order the unit with the remote. They sell it with and without...
Old 04-05-2015, 07:56 PM   #9
Thanks for the conformation just using the "bypass" switch if ever need...
And being cheaper than the portable ones, even better.
Old 04-06-2015, 06:16 PM   #10
WolfWhistle's Avatar
Originally Posted by stevejd235 View Post
Taken,
It could be located inside the access compartment in the "super pantry" behind the utility wall. Plenty of room. While in there, I would add a 110Vac outlet on the panel so you will have a outlet on that end of the sofa or dinette.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
