Old 06-27-2016, 12:01 AM   #1
Chrism28's Avatar
Suspension Grease fittings
Went to grease the zirks on my suspension before our outing this weekend second trip on the new unit and three zirks wouldn't take grease as if they were plugged and suggestions on getting grease in them
2017 hyper lite 29hfs
2012 dodge 2500 cummins
Chrism28 is offline   Reply With Quote
Old 06-27-2016, 01:26 AM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
It's possible that the fitting itself is bad. I changed mine out for a 90° fitting so it's easier to get on it.
It also maybe dried up solid in the hole of the bolt. In this case I'd pull the bolt, remove the fitting and clean out the hole.
And/or you may have to lift the coach up by the frame to unload the suspension so the grease can escape from the hole to the bushing.
05CrewDually is offline   Reply With Quote
Old 06-27-2016, 02:31 PM   #3
Heat on zerk fittings will usually loosen them up. (heat gun or torch both work great).
jkcolo is offline   Reply With Quote
Old 06-27-2016, 03:01 PM   #4
Replace with New Zerks,even though they Were New some dummy probably "Drove/Hit them in with a Hammer"! Auto parts have Zerks! Youroo!!
suspension
