09-22-2016, 01:45 PM
Swivel arm TV mount suggestions
I'm looking to add a TV mount that swivels out on an arm and also locks to the wall for transport. Any recommendations? I think the space for the 29hfs holds a 32" or maybe even a thin bezel 40".
Thanks!
09-22-2016, 02:17 PM
*TVFORMYRV* has a lot of different mounts.
The photo below is very similar to the one in my rig.
09-22-2016, 02:31 PM
X2
This is what I installed with my new Samsung LED TV in my motorhome.
Solid as a rock and like the locking pin when moving.
09-22-2016, 02:41 PM
Originally Posted by Iggy
X2
That looks like a great mount. Is mounting it to another peice of wood instead of directly to the wall stud the best way to mount?
09-22-2016, 09:24 PM
I also have a 29hfs and have the pull out mount that swivels about 45 degrees so the angle of view is almost perfect for our recliner optioned slide out and a samsung 40" led tv fits perfect with about an inch to spare on top and bottom
09-22-2016, 09:26 PM
The tv and mount were both purchased at HH Gregg
09-22-2016, 09:38 PM
For the grandkids or any guests who stay in the garage i put in a samsung 28" led tv with a samsung bluray player mounted above it. The mount for this one was a Omni small tilt wall mount (model #OS40TP). The living room mount in the before post is a Omni full tilt, pan mount (model #OC80FM)
09-22-2016, 11:33 PM
Originally Posted by Sayitdog
I also have a 29hfs and have the pull out mount that swivels about 45 degrees so the angle of view is almost perfect for our recliner optioned slide out and a samsung 40" led tv fits perfect with about an inch to spare on top and bottom Attachment 120998
Thats awesome! Based on the model number, it doesn't appear to have any kind of locking mechanism during transport. How did you stabilize your TV during transport?
09-23-2016, 04:05 AM
Just made sure all the mounting screws are tight and also the bolts that are also used as a hinge are snug enough not to move without a little bit of effort. I also bought black covers that slip over both tv's and are held on with a velcro strip. I make sure before moving trailer that the tv mount is collapsed flat against the wall. When the slide out is all the way in there is several inches between the side of the slide out and the front of the covered tv which i found is a great place to keep the small throw pillows that came with the couch/triple recliner.
09-23-2016, 04:21 AM
09-23-2016, 08:06 AM
Have pulled over two thousand miles since installing tv's this january and no problems yet. I really enjoy something i find a challenge (our 1st rv and picked it up this january) with something to do with our rv and figuring out a way to fix it. Our rv came with a sewer storage container underneath which was only large enough for 10' of collapsed hose and no fittings and was installed with the fuel station hose container at one end and the rear stabilizer jack at the other making it impossible to open the end caps enough to put a hose in it. So found a sewer hose holder on here and made one which holde 2 10' collapsed sections and the fittings, with a slide out tray. Made out of 5" square pvc fence post 8' long and a pvc gutter with both ends glued on for the tray and hasps that hold the end cap on. Also enjoy these forums for a chance to help others as others have helped me. Attachment 121012Attachment 121013Attachment 121014
Do you have any pics of what the TV mount looks like mounted to the wall? I'm trying to figure out if a single stud mounting holes is enough to support the weight of the TV.
Awesome sewage storage solution! Do you have any pics of how it mounts to the carriage?
09-23-2016, 08:51 AM
I was only going to use screws but when I installed the wood panel I Gorilla glued it to the wall to insure it won't come off. I still have to stain it or cover with some contact paper soon.
09-23-2016, 11:02 AM
That is what i used and the board in my rv wall is in the center and i think it is a manufactured 2x4 turned sideways, mine is about 3 1/2" wide. 1st and 2nd pic is with pillow in gap.
09-23-2016, 11:10 AM
3rd is of tv mount collapsed, 4th is of mount fully extended and turned toward couch/recliners, 5th is of mount lag screws into center wall stud (forgot to measure twice before drilling so had to move mount higher to get tv centered vertically), and last is of view from couch/recliner.
09-23-2016, 11:16 AM
Huntsville TX
Very cool Idea
Very cool idea..... Great job
09-23-2016, 01:33 PM
I would like to do this, as well.
09-23-2016, 07:24 PM
Television mount
When I upgraded the television in my Sunseeker I took the suggestion of another member and used Monoprice to buy the articulated mount(s).
TV Wall Mounts
This is the thread I posted to help out when I bought the mount and installed it. I checked that thread and all of the photos I uploaded are gone!
I can repost or send if needed.
http://www.forestriverforums.com/for...per-21544.html
Hope this helps
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
09-24-2016, 05:44 PM
I had a cheapo from Wallyworld ... recently went with a good one from Lowes. It was about $90 ... I use a strap when traveling for peace of mind. Been in some terrible roads with no problems.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
