Old 09-22-2016, 02:45 PM   #1
Swivel arm TV mount suggestions
I'm looking to add a TV mount that swivels out on an arm and also locks to the wall for transport. Any recommendations? I think the space for the 29hfs holds a 32" or maybe even a thin bezel 40".
Thanks!
Toneaero is offline   Reply With Quote
Old 09-22-2016, 03:17 PM   #2
*TVFORMYRV* has a lot of different mounts.
The photo below is very similar to the one in my rig.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-22-2016, 03:31 PM   #3
Iggy's Avatar
X2
This is what I installed with my new Samsung LED TV in my motorhome.
Solid as a rock and like the locking pin when moving.
ID:	120968   Click image for larger version
ID:	120969   Click image for larger version
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 09-22-2016, 03:41 PM   #4
Originally Posted by Iggy View Post
X2
That looks like a great mount. Is mounting it to another peice of wood instead of directly to the wall stud the best way to mount?
Old 09-22-2016, 10:24 PM   #5
Sayitdog's Avatar
I also have a 29hfs and have the pull out mount that swivels about 45 degrees so the angle of view is almost perfect for our recliner optioned slide out and a samsung 40" led tv fits perfect with about an inch to spare on top and bottomClick image for larger version
Name:	ImageUploadedByForest River Forums1474597477.460665.jpg
Sayitdog is offline   Reply With Quote
Old 09-22-2016, 10:26 PM   #6
Sayitdog's Avatar
The tv and mount were both purchased at HH Gregg
Old 09-22-2016, 10:38 PM   #7
Sayitdog's Avatar
For the grandkids or any guests who stay in the garage i put in a samsung 28" led tv with a samsung bluray player mounted above it. The mount for this one was a Omni small tilt wall mount (model #OS40TP). The living room mount in the before post is a Omni full tilt, pan mount (model #OC80FM)Click image for larger version
Name:	ImageUploadedByForest River Forums1474598312.518629.jpg
Old 09-23-2016, 12:33 AM   #8
Originally Posted by Sayitdog View Post
I also have a 29hfs and have the pull out mount that swivels about 45 degrees so the angle of view is almost perfect for our recliner optioned slide out and a samsung 40" led tv fits perfect with about an inch to spare on top and bottomAttachment 120998
Thats awesome! Based on the model number, it doesn't appear to have any kind of locking mechanism during transport. How did you stabilize your TV during transport?
Old 09-23-2016, 05:05 AM   #9
Sayitdog's Avatar
Just made sure all the mounting screws are tight and also the bolts that are also used as a hinge are snug enough not to move without a little bit of effort. I also bought black covers that slip over both tv's and are held on with a velcro strip. I make sure before moving trailer that the tv mount is collapsed flat against the wall. When the slide out is all the way in there is several inches between the side of the slide out and the front of the covered tv which i found is a great place to keep the small throw pillows that came with the couch/triple recliner.
Old 09-23-2016, 05:21 AM   #10
Sayitdog's Avatar
Have pulled over two thousand miles since installing tv's this january and no problems yet. I really enjoy something i find a challenge (our 1st rv and picked it up this january) with something to do with our rv and figuring out a way to fix it. Our rv came with a sewer storage container underneath which was only large enough for 10' of collapsed hose and no fittings and was installed with the fuel station hose container at one end and the rear stabilizer jack at the other making it impossible to open the end caps enough to put a hose in it. So found a sewer hose holder on here and made one which holde 2 10' collapsed sections and the fittings, with a slide out tray. Made out of 5" square pvc fence post 8' long and a pvc gutter with both ends glued on for the tray and hasps that hold the end cap on. Also enjoy these forums for a chance to help others as others have helped me.Click image for larger version
Name:	ImageUploadedByForest River Forums1474622468.893173.jpg
ID:	121012Click image for larger version
Name:	ImageUploadedByForest River Forums1474622491.242677.jpg
ID:	121013Click image for larger version
Name:	ImageUploadedByForest River Forums1474622512.043924.jpg
mount, tv mount
