Old 10-27-2015, 10:24 AM   #1
roguepra's Avatar
Tank level lights out
Well we are set up in fla. And the tank..water and battery level lights are out..also the water pump..anyone have any ideas what might cause this...we are plugged into shore power...the battery has a charge...the 12v breaker was blown but there isnt any change when its pushed in...cant get any service on the phone from the dealer..any ideas ?
2016 XLR 27hfs
2014 Tundra SR5/TRD 5.7 Firestone Airbags
Blue Ox WDH
2015 Roadglide spec
2012 switchback mechanic..(wife's)
roguepra is offline   Reply With Quote
Old 10-27-2015, 10:47 AM   #2
TURBS's Avatar
Checked your fuses?
Old 10-27-2015, 10:55 AM   #3
When you try to reset the breaker, does it trip again right away?
If so, you've probably got a short circuit somewhere.
The breaker is doing what it should to prevent a fire.
You may need a mechanic, but you can try turning off all the 12V loads.
If you can then reset the breaker, the short is associated with one of the things you turned off. Turn them back on one at a time, and you might be able to narrow down the culprit.
The water pump motor is one possible load that might fail shorted.
Gyrogearloose is offline   Reply With Quote
Old 10-27-2015, 10:57 AM   #4
TURBS's Avatar
The circuit breaker may be bad.
Old 10-27-2015, 11:26 AM   #5
roguepra's Avatar
Thanks guys blown fuse....now to see why...
2016 XLR 27hfs
Blue Ox WDH
2015 Roadglide spec
Old 10-28-2015, 11:09 AM   #6
chpence1's Avatar
Wouldn't some sort of schematic be helpful.
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 10-28-2015, 11:57 AM   #7
Yup.
I have a feeling that there isn't one, for my trailer at least.
Old 10-28-2015, 02:01 PM   #8
chpence1's Avatar
Back in the old days it didn't matter. ......
Cow Bell
light, tank
