Old 06-01-2015, 10:50 PM   #11
Lvn2tvl's Avatar
I'll bet most that are having an issue have solid wall TTers with rubber roofs. Antennas need metal ground plane to work correctly. Had the same issue with two way radios on boats 15-20 years ago. Had to use a 12" x 12" metal area below antenna to allow them to work. Discovered metal duct tape worked great since surface rarely was flat, it was easy to cut to shape, and it was stuck to gel coated fiberglass. This however would NOT be an option for rubber roofed trailers. The adapter to connect radio to the TV antenna is an excellent solution.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 06-03-2015, 06:57 PM   #12
STLfan's Avatar
I purchased the connector from the link provided but should've read more carefully. It is a Motorola connector and not standard coaxial connection. Had to buy the additional adapter today will arrive tomorrow.
STLfan is offline   Reply With Quote
Old 06-03-2015, 07:15 PM   #13
The splitter and adapter is a solution BUT WHY ISN'T ANYONE DEMANDING FLAGSTAFF TO SUPPLY AN AM-FM ANTENNA THAT WORKS?? Connecting to the TV antenna will only work with FM and the weather bands.
MartyQ is offline   Reply With Quote
Old 06-03-2015, 07:23 PM   #14
member
Sorry my bad. I should of looked better also I to received the cable today and found out it was the wrong connection. where did you get the adapter and what is it called ??
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 06-03-2015, 07:25 PM   #15
PhoneDude 8289's Avatar
Using your television antenna is the way to go but you will only pick up (UHF) FM stations. I made the switch and am happy with it. You can also pick up NOAA weather band, several frequencies 162.400 MHz up to 162.550 MHz, there are seven in all depending what part of the country you are in
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-04-2015, 11:47 AM   #16
STLfan's Avatar
This is what I bought from Amazon and it is arriving today. I will post if it works or not
DHT Handheld Antenna Cable for Wouxun Baofeng Quasheng Linton - Adapter for UHF Base and Mobile Antennas - SMA Female to UHF SO-239 Female Connectors 6''
Old 06-04-2015, 04:57 PM   #17
STLfan's Avatar
Never mind do not buy the adapter from the link I posted above. Just got mine today and it's for the small coaxial connection.
Old 06-05-2015, 05:41 PM   #18
Is the small whip ant up on the roof?
laurajean is offline   Reply With Quote
Old 06-07-2015, 08:06 AM   #19
STLfan's Avatar
Yes but not really effective on rubber I think.
Old 06-10-2015, 04:39 PM   #20
member
I just cut the end and puta common rg 6 cable connecter on the wire but the wire is strand so I tin sodered it to make it soled it works perfect
radio, reception
