Old 05-13-2015, 04:41 PM   #11
Homebrew's Avatar
Not yet - still waiting
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 05-14-2015, 07:31 AM   #12
I have the exact same crack on my 2015 XLR. I have some other warranty work to get done so I will probably have the dealer replace it when I get everything else done. For now I drilled a small hole at the end of the crack to prevent it from spreading any further.
klarowe is offline   Reply With Quote
Old 05-14-2015, 07:38 AM   #13
Suggestion. When you get the new fenders, get a bunch of 3/16" pop rivet washers and make spacers to install between the fender and the camper to prevent over tightening and cracking the new ones.
Old 05-14-2015, 11:00 AM   #14
It seems like just a couple small washers would prevent this. Just need to distribute the pressure out to a slightly larger area. But a make-shift bushing like OldCoot suggest would be ideal.
Old 05-16-2015, 06:08 PM   #15
WolfWhistle's Avatar
Mine aren't cracked... But are pulled down pretty tight. I'm going to get washers to hopefully stop any future cracking
Hyperlite 29HFS - 2015
2017 F-250 4x4 6.2L Gas
Old 05-16-2015, 09:58 PM   #16
Got my new fender last week. Came ups in a big box.
2000XLifted is offline   Reply With Quote
Old 05-16-2015, 10:03 PM   #17
When I repaired the blowout damage on our 08Flagstaff fender, I also put a washer on the outside to spread the load under the screws.
