Old 06-28-2015, 01:04 PM   #11
Originally Posted by bubbles View Post
I believe the issue with the tailgater and splitters is if there is a splitter in the input coax from the sat dish to the receiver. There is no issue if the splitter(s) is/are after the receiver output to the tv's. I believe this is how OC's coax interconnect is. Some rv's have a splitter to all tv's in the park cable coax input side of the selector switch for the tv's input source (sat/cable/ant) and some don't even have a selector switch. I believe this is why some tailgater installs have issues. JMO
I also have 3 input coax hook ups for the Tailgater. One from the pinbox, one from the ladder and the factory mounted one on the side and they all feed into one coax going to the box.
Old 06-28-2015, 01:12 PM   #12
so how did you connect the 3 coax cables together?
Tim
TimVWulp is online now   Reply With Quote
Old 06-28-2015, 01:25 PM   #13
Tim
With a 4 way connector. 2 Pcs F Adapter F Male to 3X F Female " " Type 4 Way RF Coax Adapter Connector | eBay
Old 06-28-2015, 02:34 PM   #14
bulldog4949's Avatar
Thanks for the feedback. Much appreciated.
2015 GMC 2500HD Duramax Denali
2015 XLR 300X12HP
2013 Polaris RZR 900 XP
bulldog4949 is offline   Reply With Quote
Old 06-28-2015, 02:39 PM   #15
bubbles's Avatar
So, as stated, no splitter in line with ant input to receiver.
Old 06-28-2015, 03:20 PM   #16
WolfWhistle's Avatar
Hi Dish Tailgater easy to set up. All you need is one coax cable to power the tailgater and get the signal from the tailgater. I use a Vip211k receiver for the trailer this unit is SD and HD capable. I have the Dish Hopper at home and can watch all the home channels I subscribe to on the Vip211k receiver. I have also added a 2 gigabit Western Digital desktop hard drive to the Vip211k receiver for a one time fee of $40. to make this a DVR receiver. The good thing about this setup is that you don't have to pay for a DVR rental ever. The set up is easy and is displayed step by step on the television each time you set the system up in a new location. The big thing is you need a clear sky to the south (no trees) or a hole through the trees to the south.
Hope this helps Tim
Tim, I did almost the same thing and have the same receiver, I bought a Winegard carry Out of ebay. I added the hard drive and paid the $40... but much smaller unit that 2 gigs... it works great. For my install I added a water "resistant" cigarette lighter plug on the utility side to power the carry out dish. Like you said, it works great when you have a clear view of the SW sky. Its hard to hit a hole in the trees, or at least, I've not had much luck. There is an app for the Android that works fairly well. Also a compass. I also learned (no book came with it) to aim in the general direction ... which means the connections are 180 degrees the other way... it matters I also find that it gets up and running if you use it often enough to get the periodic upgrades from Dish. If you don't use it often, you will probably have to call Dish for tech help.... they can push upgrades to you if need be.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-29-2015, 06:05 PM   #17
Have the Pathway X2 which has 2 connections, I ran the second connection to the bedroom tv, use the sat. connection on the XLR for the living room. Easy set up and stable in the winds.
wrsmsgt
2012 HD 2500 DuraMax
2015 XLR ThunderBolt 340x12hp
wrsmsgt is offline   Reply With Quote
satellite
