Old 06-20-2015, 04:47 PM   #1
WolfWhistle's Avatar
tongue box
I've been concerned about having batteries or generator (or even LP tanks) walk off when I leave them on the tongue unattended or in certain neighborhoods; and have been looking for a tongue box that would do it all and have found nada.... now there are fabricators that for a phenomenal phee can make anything you can dream up in whatever kind of metal you would like. But, I don't want to spend a thousand bucks, either.
I came up with this basic design and sizing... and am going to hit HD tomorrow for wood, etc. At this size, it won't hit in a tight turn and my 2500 doesn't have a problem with the added tongue weight.
Now I really would like to have a metal top or something that will really hold up to the weather; painted plywood will not... even marine playwood gets ugly in a couple of years. I have thought about coating the box inside and out with pickup bed liner or even have Rhino coat it, but again its costly.
Besides the vents (12 x 12)... or? I'm thinking that being able to lift the top a little and still maintain security, would be good.
I also know that if someone really wants to get to it, they can. But, I want the thief to at least make some noise.
If anyone has any ideas, criticisms or suggestions about this box, let me know.
Name:	tongue box to hold gen, LP tanks, 2 batteries.png
ID:	80574   Click image for larger version
Name:	TB outside.png
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-20-2015, 05:12 PM   #2
tjm
A plywood box would add a bunch of weight imo. Cable lock and a cover when not in use for the generator is what I would do.
Sent from my iPad using Tapatalk
tjm is online now   Reply With Quote
Old 06-20-2015, 05:19 PM   #3
Go to a metal fab shop and have it made out of alum.
Old 06-20-2015, 08:02 PM   #4
arpipeliner's Avatar
Especially diamond plate. Any boat maker or repair can do it too.
arpipeliner is offline   Reply With Quote
Old 06-20-2015, 08:09 PM   #5
Taranwanderer's Avatar
+1 on the aluminum. It'll cost more at first, but the weight savings will be worth it. Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-21-2015, 03:30 AM   #6
Play Harder's Avatar
WW go to fab shop I'll bet cheaper than you think - with the Honda in there your gonna want more security than a wood box - plus I'd put one of those gorilla chains around it bolted to frame - even a cut off wheel on a portable cut off tool has a hard time cutting though the gorilla chain -( hardened steel)
You know if you go to lowes - they have diamond plate and can cut it to your specs - just need to find someone to weld it --- also I believe if you went to a metal yard - they will cut to size too...
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 06-21-2015, 06:35 AM   #7
I agree completely that aluminum is the way to go and there's a fabricator in the little town north of me. I'll check with them on monday. If you haven't bought metal in a while you will be shocked at the price. I've actually priced buying diamond plate on line and having it shipped here. It takes one 48 x 96 plus one 24 x 96 and one 2 x 48 which comes to over $500 with shipping. I would save $200 if I could pick it up close by.
Old 06-22-2015, 08:14 PM   #8
WW I think maybe go 2 aluminum boxes - 1 for propane 46 by 14 and a triangle tung box in front - on Amazon w free shipping looks like it would be under $250 - you might need to move locking mech for back box - might be a cheaper less hassle waY to go
Old 06-22-2015, 08:28 PM   #9
asquared's Avatar
OP - Just remember it is illegal to lock access to the propane tanks. You can lock them in place and they can be behind an unlocked door but you can't lock access to the valves themselves.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-22-2015, 08:29 PM   #10
asquared's Avatar
Guys let's keep on topic. Several off topic posts have been deleted. Thanks.
2014 Sabre 34REQS-6
