Old 11-21-2016, 09:00 AM   #21
This thread is always worth a read. Like others have said, pulling is one thing, sway and being able to safely stop are a whole other story.
http://www.forestriverforums.com/for...ler-53124.html
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 11-21-2016, 08:02 PM   #22
Rzrfan's Avatar
We bought 2015 30hds started with Dodge 2500 hemi. Power was fine but couldn't get rid of the sway. The trailer has a lot of tongue weight. We use a equilizer 14000 lbs hitch. Better ride but still had some sway. Went back to Chevy dually which is probably a over kill. But now one finger on steering wheel can't even tell the trailer back there! Can't beat the stability of the rear duals! Finally happy!!!Click image for larger version
Name:	ImageUploadedByForest River Forums1479776256.932695.jpg
Rzrfan is offline   Reply With Quote
Old 11-21-2016, 10:55 PM   #23
Hedrock's Avatar
Exactly what we did. From this...
Name:	ImageUploadedByForest River Forums1479786823.673334.jpg
To this...
Name:	ImageUploadedByForest River Forums1479786868.026972.jpg
Over kill I know but the piece of mind was worth it.
2016 Hyper Lite XLR 30HDS
Hedrock is offline   Reply With Quote
Old 11-22-2016, 11:55 AM   #24
Rzrfan's Avatar
Very nice setup! I think the 30hds looks great behind dually pickup! It's a big camper! We love ours!
Old 11-22-2016, 01:34 PM   #25
northstar1960's Avatar
Originally Posted by Robjr66 View Post
Thanks everyone....
Below is the link for the towing guide for my 2013 F150....
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
I have the 3.5 GTDI V6, 3.55 gears, Supercrew 4x4 w/ 145" bed. With the trailer towing package...
Gross combined weight rating (GCWR) - 15,500lb with Maximum Loaded Trailer Weight = 9600lb...
Thoughts? Am I understanding it correctly? thanks,
in all honesty you can crunch #'s all day will the 150 eco boost can you do it yes will it be enjoyable no. you be over your numbers real quick . so unless you really don't plan on towing it often . like 2 times a year then get a 3/4 or better . your be over just with TW on your payload and even over your GCWR
northstar1960 is offline   Reply With Quote
Old 11-22-2016, 02:49 PM   #26
davidjacob's Avatar
I love the way our Titan XD tows the 29hfs. I forget it's back there even when passed by semi trucks. We have taken it to some of the beaten path places and never once did I feel the truck was struggling. We towed a gulf stream 19kd with our old ram 1500 4x4 across country and my wife said never again. With the Titan she actually enjoys driving it.
Here we are in New Mexico
ID:	125613   Click image for larger version
2017 XLR 29HFS
2016 Nissan Titan XD Cummins V8
davidjacob is offline   Reply With Quote
Old 11-22-2016, 03:47 PM   #27
rp53's Avatar
honestly your truck might pull it but you are not going to be a happy camper and that is what it is all about. I had a Chevy Colorado max tow of 7000lb max tongue weight 900. my TT weighs 4500 loaded tongue weight of 560lb, well within limits right ! well it towed it but going through mountains was tough on it and when the big trucks passed it wasn't fun. sure Ford, Chevy and dodge are going to say you can tow X amount however IMHO it is all about feeling comfortable and safe.
2017 Micro Lite 21FBRS (sold)
2019 GMC Sierra 2500 HD extra cab Z71
looking for the perfect 5er over the winter
rp53 is offline   Reply With Quote
Old 11-29-2016, 09:10 PM   #28
Play Harder's Avatar
Towing - XLR 30HDS
I towed my 29hfs home from Iowa to Seattle, Wa w my dads 1500 ford eco boost w max tow package - thought it would save gas from my Chevy -- we where very wrong on that point very bad Milage 6mph max all the way home
As for pulling the ecoboost had zero issue pulling the 29hfs up to about 65 then you would get some serious sway but that could be because the first use of the WDH hitch
The 6 cylyder turbo ecoboost really surprised me w 8 speed transmission - you could stop at the bottom of any hill and the ecoboost would pull up to 65 w no problem- no straining just quick acceleration to 65 - more power than my 6liter Chevy at curtain RPMs
I was impressed
Note: The hitched weight did squat the truck a bit and that could of been the sway issue - I would of added airbags if it was my truck I believe max tow package is rated to 13500lbs towing crazy for a 1500
Play Harder is offline   Reply With Quote
Old 12-29-2016, 02:35 PM   #29
i have a 2017 30hds have a 2015 dodge ram built to tow has 392 gears air ride trailer tow package trailer is 7645. harley ultra is 1098 lbs truck says 11500. tows like it is not even there.but load your trailer and way it .better safe then sorry .love mine went from keystone out back front garage to back much more room. will see if as good as old trailer but love it so far
bingo king is offline   Reply With Quote
Old 02-15-2017, 10:35 AM   #30
We just picked up a new, 2017 30HDS with the TUSON Sway Control System. We are pulling with a 2009 Dodge 2500 HD Cummins, and have no problem.
HyperCamp is offline   Reply With Quote
Old 03-16-2017, 10:23 AM   #31
Can you guys fill me in on what type of wheel chucks or tie downs you use on your Harley?
I'm getting a 30HDs soon and I will be hauling a soft tail and an ultra limited. Thanks
Tankmaster is offline   Reply With Quote
Old 03-16-2017, 10:45 AM   #32
danny4127's Avatar
CONDOR
Danny and Beverly Plus Panhead (chiweenie)
2019 5th wheel
2016 DOGE RAM 2500
2013 HARLEY TRI-GLIDE
danny4127 is offline   Reply With Quote
Old 03-16-2017, 10:57 AM   #33
Condor +2. However many options are available at different price points.
I simply roll into chock and then use 4 straps from moto to floor tie downs. (2 forward, 2 back) Never a problem in many years/miles.
gloryracing is offline   Reply With Quote
Old 03-16-2017, 01:11 PM   #34
depends on how much you want to spend I use the HF knock off of the condor . it's only $60 or so and works just as well as the $300 condor . I've got 12xxxx miles hauling the bike with the HF chock and never an issue
Old 03-16-2017, 01:45 PM   #35
I also have a 30HDS, and love it! I use Baxley chocks. Ride on, step off. I have 3 of the in different trailers, have used them for years, absolutely no issues, and they have a small footprint.
Russell and Nancy
2017 XLR 30HDS Hyper Lite TH
Prowler Regal TT
Dodge Ram 2500 HD Cummins
2018 Ultra Limited
Old 03-16-2017, 05:47 PM   #36
Taranwanderer's Avatar
Big fan of the B&W Biker Bars. Do a search on them in here, several write ups. They work really well and you don't need straps.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 03-16-2017, 06:21 PM   #37
I am not even reading because I know the weight police are all over this one. I hauled the 29 with a 2014 ram 1500 no problems. to road bikes from michigan to daytona bike week and back.
Kimber45 is offline   Reply With Quote
Old 03-22-2017, 09:35 PM   #38
Towing - XLR 30HDS
I have a 2017 29hfs. I was pulling with a 2015 f150 super crew with the 3.5. Eco. It pulled just fine. HOWEVER there were occasional times you would feel everything. Based on that I didn't want to take it on any long trips. I decided to dump the f150 and went to a 2016 F350 diesel and it's amazing. Yes a lot of truck but now if I upgrade I won't have to worry about trucks! To note. Sway wasn't an issue as I bought the best sway hitch there was.
mjwhiteis is offline   Reply With Quote
towing, xlr
