Old 05-26-2016, 03:10 PM   #1
Traveling with a full water tank
I normally travel with a quarter tank of water for roadside use and then hook up to water at the campground.
Going to a campground about 35 miles away with no water hookups. What are the thoughts on filling the tank at home before leaving?
Will I leave the tank behind on the road if I hit a good bump?
Not taking the Harley so weight is not an issue.
Thanks!
breezyhillfarm is offline   Reply With Quote
Old 05-26-2016, 03:58 PM   #2
Head Rambler
You should be fine toting a tank of water since you're not carrying weight in the garage.
I don't do it often, but I've hauled a tank full when I know there won't be any readily available at the final location.
Gotta go campin!
Old 05-26-2016, 04:13 PM   #3
kevnval's Avatar
You shouldn't have a problem. I have done it countless times over the years...as much of our camping is boon docking at Bluegrass festivals where you can't easily access a water supply.
2015 Sabre Silloutte Select 312 RKDS
2015 RAM 2500 CC 4x4 SXT 6.4l Hemi 3:73's
Former Michelin Tire Guy
kevnval is offline   Reply With Quote
Old 05-26-2016, 04:47 PM   #4
Thanks to both of you.
Old 05-26-2016, 04:48 PM   #5
I'll start by saying we've only used our TH two times so far, so I'm a newbie However, both times we went with a full tank of water, as the paddock area at the race track we go to just has electric, no water. We haven't had any problems, and both times we had two sport bikes in the garage.
chrissybird is offline   Reply With Quote
Old 05-26-2016, 09:13 PM   #6
Thanks for the info. Always helpful.
2014 XLR 27 HFS
2006 Ford F450 Dually Diesel
2015 Harley Freewheeler
2004 Harley Road King Custom
Old 05-27-2016, 12:23 AM   #7
Play Harder's Avatar
I always travel w full tank of water and my Cam Am Spyder in back no issues -
Play Harder is offline   Reply With Quote
Old 05-27-2016, 11:39 AM   #8
mcmartinez's Avatar
I always travel with a full tank of fresh water. I need the additional weight on the tongue to help with sway control. Never had a problem.
Mario Martinez
2703WS Rockwood Super Lite (6,400 Dry weight)
Tow Vehicle - 2010 Ford F-150 Super Crew
5.4L V-8 6-spd auto 2x2 9,800 Lbs. towing capacity.
mcmartinez is offline   Reply With Quote
Old 05-27-2016, 12:02 PM   #9
Tom48's Avatar
Carried 100 gal everywhere we went in the old TH and sold it at ten years old. Tanks were fine. Still secure. I did like that there were two 50s and have wondered about the new TH ---- that we will evidently finally get to pick up tomorrow---- as it has a single 100 plus a second 60 and neither appears to have mid tank support. Guess I might wind up adding an angle iron cross piece, but maybe FR knows what they are doing so we shall see.
Tom48 is offline   Reply With Quote
Old 05-27-2016, 12:08 PM   #10
My old Th carried 100 gals fresh water. I never had a problem hauling it with the tank full. Present 5er holds 60 gals and I don't have any problems hauling with it full, if we're going somewhere where there isn't a fresh water hook up. I also have 2, 50 gal collapsible water bladders that I use. When travelling to private campgrounds on a long 2000 mile trip I fill approx. 1/3 full for pit stops. My dually has a long box so the bladders fit just fine.
Pipeman is offline   Reply With Quote
tank, travel, water, water tank
