Old 06-10-2015, 11:07 AM   #1
TV mount in nitro 24fqls
Planning on mounting a tv on the wall like shown in the xlr nitro brochure.
I can feel a stud about 12'' from the corner next to the refrigerator beneath
a trim strip. I assume I need to install a wall mount on that stud or is there
some additional structure in the wall so the mount can be shifted slightly to
the right? How long of a screw or lag bolt can be used ? Any recommendations
would be appreciated.
OOPs 24FQSL
wulfe513 is offline   Reply With Quote
Old 06-10-2015, 03:38 PM   #2
Chrism28's Avatar
There's a spot for it lower in the wall in the middle at least on mine it's a 14 if you tap around on the wall you will tell there's a backer there just don't use a lag bolt that will go to the bathroom
2014 xlr nitro 24fqsl
Chrism28 is offline   Reply With Quote
Old 06-11-2015, 10:12 AM   #3
Mine is a 2015 but built mid 2014. Where the trim strip is, feels solid with no flex about 1.5"? either side of that strip. That seems like the best place but it is a little too close to the corner for a 32" with the mount I have. Wish I had xray vision to know for sure. Maybe I need a different mount so I can hit that stud. I can feel something solid more towards the middle where you suggest but I have to depress the panel about 1/8" or more before I feel some structure.
Old 06-11-2015, 03:50 PM   #4
Chrism28's Avatar
Mine was pretty much directly across from the freezer door some had a sticker there saying where to mount the TV mine didn't so I just looked at different ones on the net till I found a pic where the sticker was and you can feel it tap just below the outlets and too the middle a bit there is somthing there
Old 06-11-2015, 06:33 PM   #5
Thanks for the info. I'll check that out tomorrow. I don't think I checked there yet. I need another mount. It's getting harder to find a new tv with an old vhs video input to match the factory av equipment. I did find and buy one at Sam's but it has a 100x200 mount or is it a 200x100. Whatever it is it's 90 degrees off what I need.
Old 06-12-2015, 10:33 PM   #6
I too have a 2015 and I found a wall mount at Wal Mart. I found that for my case a 28" T.V. fit best. Have you'll done very many mods to your th yet? I think I am about done now.
hdmtnrider is offline   Reply With Quote
Old 06-12-2015, 10:33 PM   #7
Go to a hardware store and get a stud finder. It's a much better solution than "feel".
2011 Flagstaff V-Lite 30 WRLS
2007 F250 SD
chasbo70 is offline   Reply With Quote
Old 06-13-2015, 01:45 AM   #8
Chrism28's Avatar
I've done all led lights and different shower curtain rod and shower head. Made my cabnet above the sink have a shelf and silverware elevated to give me more space and adding a fold up counter extension and put boom Matt in the gen compartment. Also installed a cig lighter plug where the tv is mounted cause I have a 12 volt TV
Old 06-13-2015, 06:38 AM   #9
I tried using a stud finder but every time I touched it, it would go off!😀
breezyhillfarm is offline   Reply With Quote
Old 06-13-2015, 07:31 AM   #10
Craigban157's Avatar
must be a defective stud finder
2015 Salem261 BHXL
2016 GMC Sierra 2500HD
2015 nights camped 90
2016 nights camped so far 120
Craigban157 is offline   Reply With Quote
mount, tv mount
